Results 1 to 7 of 7
09-29-2013, 10:42 PM #15000 RPM
- Dec 2008
- San Diego, CA
- 263
- 10
- 26
Adding cup to a propeller at home
I have a small aluminum prop that was hacked up by someone attempting to do a modification. They basically ground the blade faces flat. I want to use the prop as a back up but it now hits the rev limiter. I would like to add some cup so the prop is at least some use.
How can I do this at home? Anyone try it? It does not need to be perfect as anything will be an improvement.
Thank you
09-29-2013, 11:31 PM #2
trailer hitch ball
09-30-2013, 04:27 PM #3
Aluminum props are easy to bend but difficult to keep from cracking!
The castings are normally VERY poor and never end up as good as new... even after a professional repairs it!!!
Take small hits with the hammer and slowly bend the blade until it's where you want it.
Try to visually match all blades ...... that's probably the most difficult thing to get right?
I sincerely wish you good luck.Thanks,
Tim Bostic
Hoss Marine Propellers
www.hossprops.com
918-479-5167 (shop)
Pugh Hydro w/260 Merc - 12" mid
1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
"New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
09-30-2013, 07:47 PM #4
I like the trailer ball--I never thought of that! Gary
10-01-2013, 04:39 PM #55000 RPM
- May 2007
- Wright City, MO USA(Transplanted Seattlite)
- 396
I have a 3 ball hitch, great, you can decide which ball fits the blade and bang away.
I use a small to moderate ball peen brass hammer, it doesn't seem to 'bend' the alum so hard at each impact site, lessening instant cracking.
10-02-2013, 07:40 AM #6
Has anyone tried balancing a prop using a mower blade balancing cone. I was told by a marina that they use one after filing nicked blades. Gary
10-02-2013, 09:13 AM #75000 RPM
- May 2007
- 396
You know I am going to have to try that!
It might crush that poor little piece of plastic.
