Results 16 to 30 of 57
10-06-2013, 06:53 AM #16
You can get a pretty good finish spraying with a primer tip (larger) but like they said it all has to sanded and buffed.
10-06-2013, 02:46 PM #17
I have a ES G100 Gel Coat Spray Gun with many different size nozzles and a HVLP Spray Gun 1.5 nozzle. I seam to get a smother finish with the HVLP Spray Gun but I think the nozzle is to small to get a good wet film thickness. I was going to get a 2.5 nozzle and give it a try. Any subjections for either Gun, Nozzle size, air presser, mixing of gel-coat?
<O</O
I am using Seahawk products: Gel-coat White Premium, Neutral Gel-coat, Black Gel-coat, Patch Aid, Styrene Reducer.
http://www.bottompaintstore.com/
<O> </O>
GCP Polyester Pigments: Purple and White mixed at different ratios.
http://www.gelcoatproducts.com/pigmentkits.html
<O></O>
All striping is done, sanded and ready to spray the Clear HI-UV Gel-coat over the top, hoping to get a better finish than I have in the past, looking for some input.<O></O>Last edited by Hydro200merc; 10-06-2013 at 02:50 PM.
10-06-2013, 03:01 PM #18
Wish I could help,when I did mine all that was available was a old style blinks pressure gun,with a large primer tip!
10-06-2013, 03:19 PM #19
10-06-2013, 03:27 PM #20
10-06-2013, 03:46 PM #21
10-06-2013, 03:52 PM #22
10-17-2013, 08:05 PM #23
Hydraulic Pump Mounting Bracket
I have fabricated a bracket to mount the Trim Pump and Hydraulic Pump for the Jack Plate to. I sandwiched the rear build head between the fuel tank and the hydraulic pump bracket. I utilized the same mounting holes for ease of removal. I am putting a Bob's 6" Set-Back Hydra Jack plate and a Single Ram Trim Bracket. Is this a good Trim Pump to use with a Single Ram Trim Bracket?
10-17-2013, 10:33 PM #24
Looking great!
10-18-2013, 05:39 PM #25
10-18-2013, 10:25 PM #26
Your doing a great job. Thanks for the pics.
DBLast edited by Da Bull; 10-19-2013 at 04:55 AM.
10-19-2013, 04:43 AM #27
Great work !
10-24-2013, 01:48 AM #28
Clear HI-UV Gel Coat
I picked up a different HVLP Spray Gun 2.5 nozzle. I seam to get a decently smother finish still a bit wave. It is a little bit slow going to get a good wet film thickness.
The Boat is Clear Coated Woooot!!!!!!
http://www.screamandfly.com/showthre...VP-Mod-Project)
10-24-2013, 06:25 AM #29
Very nice!
93 STV Mod VP/MERC 2.5 200
Proverbs 4:18-20
-- John F. Kennedy 1962
10-25-2013, 11:26 PM #30
