Results 1 to 12 of 12
09-26-2013, 04:20 PM #1
1980 13' Twistercraft 150 merc NOS
I have owned it for near 2 years. Put it in water once and threw throttle return spring so I put it back on trailer. Starts and runs good but life has a funny way of changing ones direction and I no longer need this boat. I have posted links to 2 threads by Moomba pertaining to the boat and motor. Pretty much covers things. I did replace switch box but did not address the rigging issues with the nitrous. It is all there but I planned on changing it to a manifold and I just didn't get that far. Boat still looks new as does motor cover. Comes with full cover on decent trailer. Has been stored indoors since I purchased it. Motor is a 150 inline on T2 mid with Speedmaster lower in case you don't want to read thru the threads but I highly recommend you do. The pictures I have are too big to post. $6500. Thanks
Rock
http://www.screamandfly.com/showthre...ghlight=moomba
http://www.screamandfly.com/showthre...ghlight=moombaTeam Junk
11-15-2013, 09:00 AM #2
We'll try this one more time then maybe split it up.
RockTeam Junk
W2F a V-King liked this post
11-15-2013, 10:19 AM #3
My Personal Boats
1996 STV River Rocket with 260 Mariner SOLD
1942 Century Sea Maid 17' Split Cockpit Barrel Stern 175 HP Flat Head 6 cyl.
2004 Moomba Mobius LSV 23' V Drive 345 HP Wakeboard Boat
03-06-2014, 05:09 PM #48000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Hey rock is that a Keller Speedo in that boat nice piece good Speedo's to
03-06-2014, 08:54 PM #5Member
- Jul 2011
- Australia
- 43
Interested in the motor only, PM me if you are keen to sell.
03-06-2014, 09:39 PM #6
03-07-2014, 08:30 AM #7
Yes Michael, it is a Keller. Good eye.
Old Racer, pm sent.
Steve,.....If he is interested in the motor I will let you know. Boat is in exact same condition as when it left New Hampshire. I only tried to use it once and it started well but ejected throttle return spring so it went back on trailer. I planned on selling motor seperate if no response to bump and have bought a 115 Chrysler Charger ( orange and white to match the boat) but would be willing to sell without motor.
RockTeam Junk
FMP liked this post
12-30-2018, 03:11 PM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
How'd the 115 turn out?
12-30-2018, 03:24 PM #9
It's a 115 Charger (whatever that is ) and is only the third Chrysler I have ever owned. It is patiently waiting for me to get my head out of my ... and decide what I am going to do with it. While it looked good on the Twistercraft why would anyone put a stock 115 Chrysler on a ultra lightweight, single seat race boat..
RockTeam Junk
12-30-2018, 03:43 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Is it a 78+ , one piece lower with side bullet pickups?
It should have TC carbs. Is it a distributor or full electronic ign? Good motors that are 3.375" x 2.8" 99ci. 165psi will work fine with good pump gas. 32-34* ign. All the good cleanup port squaring, reeds etc work. Those 78+ 115 were underated, Chargers usually were blue cowl those years , changed colors a couple times but its really just SS prop black coated and ptt. What year, tag is in lower front cowl. Weight is a lean 265lbs with a 20" leg.
In 1977 the 99 ci with TC and 165psi was a 135. In 78 they stroked to 2.876 and the 103ci 140 was the replacement.
The short 2.8 some say turn better rpm but my 103 turns 6200 , ex bridges cut ports cleaned etc.
Could also be a highring, pull the covers have a peekLast edited by FMP; 12-30-2018 at 05:12 PM.
01-02-2019, 11:59 AM #11
I am going thru the motor pile and getting everything in good running condition cuz everything is going up for sale. Moving into a much, much smaller shop and would rather sell some of this stuff than move it.When I get to the Chrysler I will definitely be in touch. You obviously know a bunch more about Chryslers than I.
RockTeam Junk
01-02-2019, 12:11 PM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That little hull looks light , should move alright. Not quite Merc fast with that Merc lower but if it's a powerflow 1.73 side bullet intakes with the right prop, height it'll run and sip fuel.
