Results 1 to 13 of 13
09-15-2013, 08:06 PM #1
Mystery Yamaha electrical part (part of trim wiring harness)
Pulling apart my wiring harness and eliminating a lot of it.
This was plugged into two bullet connectors near the trim switch in the lower cowl and grounded to block. It is color coded for the trim system.
The system works fine with it removed,. The black block shaped end somewhat soft, like a hard rubber material. Looked at parts diagrams and could not find anything like it.
What is it?
21' Paramount
Mercury 300 Promax
09-15-2013, 08:31 PM #2
Just checked my spare harness and there's on there too.
21' Paramount
Mercury 300 Promax
09-15-2013, 08:44 PM #3
Your remote trim switch still works? Just thinking out loud, some circuits have active ground and apply 12volts to relay. Maybe your remote has active 12 volts and needs ground for remote switch?
There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
Quinten
86' Hydrostream Vking YT, 2.4 Bridgeport EFI
(Rigging and interior in the works)
88' Hydrostream Voyager, 2.4 200 Merc
Boat of The Month Feb. 2009
resto here, http://forums.screamandfly.com/forum...d.php?t=144414
Dedicated to you Dad, I miss you! 1935-2008
09-15-2013, 09:43 PM #4
Remote on steering wheel and cowl mounted switches work fine. Boat is all buttoned up for the night but I am wondering if its a resistor that effects trim speed.
21' Paramount
Mercury 300 Promax
09-15-2013, 10:17 PM #5
Maybe put an ohm meter on the ground and each of the leads. Open, closed, resistance? Might tell you something. I just can't think of a good reason why a control wire would want any ground unless that was the circuit it was meant to complete. Oh well, I tried.
Quinten
09-15-2013, 10:25 PM #6
09-15-2013, 10:38 PM #7
Man, that's pretty close to a closed circuit. I'm guessing your motor is 2 wire, do your remote buttons apply voltage or ground to your trim relays? Maybe a triac switch, overload? Instead of a fuse. Don't let me screw you up, I know just enough to confuse somebody.
Quinten
09-16-2013, 02:49 AM #8
Looks to me like quick connects if another remote was needed.
09-16-2013, 06:34 AM #97000 RPM
- Sep 2002
- Lakeland,Fla
- 2,500
No one had ever been able to tell me what it is. Check it like a diode, I think it may be prevent you from hitting both trim switches at the same time, as in one going up and one going down.
Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
We Put The F. U. in FUN
94 17MA Maverick 115 Yamaha
2006 Mustang GT, with a belt driven air cleaner
09-16-2013, 09:13 AM #10
Rumor is its a diode that prevents a high voltage spike when the trim motor stops.
21' Paramount
Mercury 300 Promax
09-16-2013, 11:17 AM #115000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
what motor?
09-16-2013, 11:35 AM #12
1994 Yamaha 130 2 stroke
21' Paramount
Mercury 300 Promax
09-16-2013, 08:32 PM #13
I believe it is a diode as well.
