Results 1 to 9 of 9
    Oct 2007
    North Port Florida
    Time to best the dead "black max", "black box" horse.
    I have seen a little bit of conflicting information in my searches, so here goes. 89' 2.4 200. Three boxes total. I have block off kit for oil injector. After that, disconnect the three boxes, link and sync and done? No wire swapping, no jumpers?
    Quote Originally Posted by mrcrsr View Post
    and you could always add more hp!!
    There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
    Quinten
    86' Hydrostream Vking YT, 2.4 Bridgeport EFI
    (Rigging and interior in the works)
    88' Hydrostream Voyager, 2.4 200 Merc
    Boat of The Month Feb. 2009
    resto here, http://forums.screamandfly.com/forum...d.php?t=144414
    Dedicated to you Dad, I miss you! 1935-2008
    Oct 2007
    North Port Florida
    Dam it! It was supposed to say "beat" not best. Freakin I pad, one finger typing sob!
    Quinten
    Need to hook the overheat head sensor wire right to the terminal block by the switch boxes .. tan/blue and the temp sensor if it has one to tan
    Oct 2007
    North Port Florida
    So, the tan/blue will theoretically activate the buzzer and tan would go to the gauge? In other words they will both be "leaving" the switch box and head for the dash?
    Quinten
    Oct 2007
    North Port Florida
    Oh wait, the terminal block will be a junction? I'll put my eyes on it, then ask if I need to. It will probably make more sense when I'm standing in front of it.
    Quinten
    Jun 2009
    louisiana
    i need these answers too so please keep the info coming.
    Houston, TX
    X2. I have the same motor but have not ditched my boxes...yet!
    Aug 2013
    Pooler Ga. outside Savannah
    Subscribed for info as well.
    "The trouble with trouble is it starts out as fun" Mark Twain.
    1989 SeaCraft 20CC
    1989 Mercury 200 EFI SN#OC126437
    Mar 2011
    Virginia
    If the wiring harness in the boat includes the trim control wires (some of the olders ones did not) then the over temp sender (Tan/blue) connects to the tan/blue at the terminal block. Disconnect tan/blue from oil inj alarm module. The tan wire from the temp. sending unit for the gage will connect to the tan wire that comes out of the side of the wiring harness bullet connector (along with the trim cntrol and indicator leads). The oil injection alaram module is disconnected and removed. The other module is usually a spark advance/idle stablizer and is not related to the oil injection. However, most remove it as well and set WOT timing to max advance desired (for 200s usually 23-25 degrees). Not sure what the third box you're referring to is (knock sensor on EFI???).
