Results 1 to 2 of 2
    Sep 2007
    Denmark Fyn Hasmark beach
    exhaust temperature on the pyrometer on EFI 2,5 ros
    Hello. Do any know the exhaust temperature on an efi 2.5 ros 1998 with pyrometer.
    When i go about 5-7000 rmp the temperature on pyrometer is 1100 celcius degree and the gauge go to max 1200 c`.
    The water pressure is about 12 PSI on gauge.
    The engine is on a tunnel boat a Hydrolift Sportcat 22 from 1994.
    Kindly Lasse
    Sep 2002
    Panama City Fla.
    1050-1100 F is what you should try to have at Wide Open Throttle. Pyros tend to give a false reading at less than wide open in many instances. Aluminum tends to melt at anything above 1100 degrees but the actual exhaust gas temp can be significantly higher.
    www.eagleoneperformance.com
