Results 1 to 11 of 11
Thread: 17' custom vee with trailer
09-03-2013, 05:19 PM #1
Too much to list
$3,500 firm but I will trade towards a 260, 280, 300 drag, s3000, power cat hull of any kind
Comes with trailer.. No power
GlennLast edited by aggiestckl; 03-09-2016 at 07:39 PM.
09-03-2013, 05:34 PM #2
New Attwood Aergo 240 Bright White and Yellow seats, New Teleflex P2000P Pro Trim dual turn signal trim switches for motor tilt and jack plate, New Premium Cabellas carpet installed, New Marine wood floor in front portion of boat (under new carpet), New Eddie Marine Battery Hold downs x2 for group 24 batteries (Powder Coated Red), New Quest battery selector switch, New on board battery charger (its a flush mount that you plug extension cord into), New Dana Marine LT-500 Hydraulic trim tabs anodized red, with anodized red switches, New hide away cleats x4, New stainless gas vents, New stainless floor drains, New Stainless LED bow light, New Sony Marine Stereo model DSX-MS60 - Ipod control that stores ipod in the stereo deck
09-03-2013, 05:35 PM #3
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> New Sony 600x4 marine amplifier, New 4x Infinity marine 6x9 speakers model 6912M (two in fiberglass boxes up front, two in heal kick board on back bench seat), New 2x gel coat fiberglass 6x9 speaker enclosures
New Stainless steel rub rail installed, New Stainless steel rub rail installed inside to trim cockpit, New Dana marine anodized red switch panel (controls bilge pump, bow and stern lights, stereo, and gauge lights), New 12v accessory outlet, New stainless steel fuel sender switch, New anodized red fuel fill cap (flip style that seals flush) from Rex Marine
New wiring, terminal and fuse block installed - no spaghetti it is all done professionally with soldered connections and heat shrink wrap, Land and Sea hot foot throttle installed
New throttle and shift cables installed, Bobs machine 6'' hydraulic jack plate, Bobs machine black hydraulic lift plate indicator gauge
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
09-03-2013, 07:51 PM #4Junior Member
- Mar 2013
- suffolk
how much does it weigh? where u located ? whats degree on v
09-03-2013, 08:08 PM #5
it is extremely light id say under 700 lbs, most likely around 550.. I am in New Jersey at 08031 but I can deliver or meet up up to 100 miles for .50 a mile
09-03-2013, 08:08 PM #6Junior Member
- Mar 2013
- suffolk
what speed were you seeing out of her
09-03-2013, 08:10 PM #7
When I had a 200 gt200 looper on it with 28P prop it was in high 80's with that heavy small heavy motor.. With a 2.5 you could probably see 100s easily
09-18-2013, 08:17 AM #8
I will trade towards a 2.5 and pay cash
TTT!
09-18-2013, 08:26 AM #9
very nice!
400 Sea Ray Express
14 foot Awesome Cat
09-21-2013, 10:22 AM #10New Member
- Oct 2012
- long island
do you have the back seat , how many gallon gas tank, how rough of water did she run in, how current are pics Reguards ED
10-01-2013, 07:21 PM #11
Sold thanks S&F.. Enjoy Ed!
