Results 1 to 4 of 4
    E-Tec Engine History Report
    Is there any way to get a report for just the last run I took? I have a complete engine history report but it wasn't exactly what I'm after...
    Thanks in advance
    Canada, East!
    What are you after?
    Engine history report will detail when values are above/below certain parameters.
    If your after specific details, you'll need to log the data while running. I can't recall how long it'll log, or if you need the dealer/BRP software to read the log, or even to make sense of the log. Recorded a couple of logs - approx 90 sec clips. and sent to BRP for analysis/confirmation, using dealer version of EV Diag.
    pointer
    We race a 150ho and wanted to see if we could get a report for the last race we did, that's all. Approx 45 mins of running time. Don't think our complete engine history report looks too good!! Had lot's of issues when we first got the motor...
    May 2006
    The latest diagnostic software versions automatically record the final 2 minutes of engine operation. There is also a flight recorder feature to customize the data grabbing intervals and which parameters to save.
    You can also clear the saved info such as rpm and water temps and start anew whenever you wish.
