Page 8 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 106 to 120 of 293
  1. #106
    Good job never a doubt in my mind.
  2. #107
    Jun 2004
    port st. lucie, fl
    its probably dumping a lot of fuel in it gary, did you do a plug reading? how does it run as far as performance compared to the downdraft system? did you try the map restrictor?
  3. #108
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by Dave Strong View Post
    Thanks Dave for that vote of confedince, appreciate it greatly....
    Quote Originally Posted by mrcrsr View Post
    Charlie, fresh set of plugs, hard pass and pulled them, they're reading dark brown, I'd rather have it a little rich over lean. Pulls much, much harder than the down draft any where in the RPM range you punch it. The .020 restricted MAP sensor made no difference at all that I could tell. It runs great, so I'm leaving well enough alone......lol.
    Gary
    Growing old is inevitable, growing up is optional.......
  4. #109
    sounds good, well done!
    Could be the gopro but it looks like that motor moves around a ton, might want to see if your steering has some air in it.
  5. #110
    Quote Originally Posted by Liberator*21 View Post
    So your wizzy linkage was the fix?
  6. #111
    Jul 2007
    Industry, PA
    Exactly what that intake likes.... a ton of fuel! I'd like to hear the fuel consumption difference after a day of boating.
    Good job Gary! I'll be running my downdraft soon. I kinda wish I would have left it on the Checkmate for a better comparison.
    85 Checkmate Starflite
    MAD/Wolf 225 EFI
  7. #112
    Mar 2006
    auckland new zealand
    that kool its up and running. did you pic up any rpms and mph? do you run pyros? if so temps?
  8. #113
    Jul 2007
    Hamilton Ohio
    I saw that too when I downloaded the clip, already on it, yeah it did have some air in it. Thanks for the catch........
    I seriously doubt all the movement will go away as there's allot more torque at the prop than ever before.....
    Well partly Dave, cranked up the fuel pressure, added vacuum port control on the EFI fuel reg., changed the ratio of advance for the TPS, loaded the bottom end with lots of fuel to cover the sudden amount of air the motor see's off idle and mid range.
    Quote Originally Posted by opsdave View Post
    Thanks Dave. Your totally correct, with 3x plus, the amount of air the motor sees, fuel is the answer. As for fuel usage, it really shouldn't be much more than before, only heavy fuel usage would be off idle and mid range and I don't spend much time at either one.......LOL.
    Quote Originally Posted by R.grover View Post
    Didn't log any numbers from the test session as it was only time spent to get the intake working properly, I do run pyros, and temps were around 1300/1350 at WOT. The prop I was running was an old stand by, not in the greatest shape.
    Gary
  9. #114
    Jan 2003
    aalsmeer
    Red face
    yeah like that,s going to happen !!!!
    but otherwise great job
    compliments for your fabrication work
    btw if you have a smart phone you could use something like this to log speed and acceleration
    www.sports-tracker.com
  10. #115
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by PanRonnie View Post
    Thanks Ronnie,
    You know me all to well.......
    I am going to re-fab a few parts that were just saw cut/drilled and used for test over the coming winter months. The linkage system will also get a rebuild in an effort to eliminate as much friction as possible in the collapsible rod section, I'll be using Teflon material to accomplish that.
    Gary
  11. #116
    Jun 2004
    port st. lucie, fl
    nice gary, i'd be interested about the fuel consumption as well. i'm hoping the intake makes a difference on my project. i reviewed the old fuel maps from the mad efi/ wolf and fueling numbers are much higher then what i have now. i originally chalked it up to just not being set up properly, maybe it does need that much fuel
  12. #117
    Jul 2007
    Industry, PA
    Charlie
    I'm sure you'll be adding fuel to your map. When I tried to run your setup last year it would just fall on its face when I backed out of the throttle once I got up on plane. I wish I would have spent more time tuning it. I'm sure you'll love it.
    MAD/Wolf 225 EFI
  13. #118
    Shreveport, La.
    I`m so glad i read this whole thread. Gary, You`ve done a very nice job and have peaked my interest in my project again. Mine is a 300XS block with everything else comming from a 1998 300PM with the same MAD intake you have. Only two problem`s i`ve had are #1, I scuffed 5 pistons (5 differant holes) one at a time after i built the motor (piston dome`s were dark color). Charlie streightened me out on that. Not enough break in time. I cranked the fuel psi up to 50lbs and rode for two month`s then backed it down to 40lbs. No more scuffed piston`s. Runs great.
    #2 problem, Off idle lean spot (sound familiar?). With my two computer system i can`t adjust fuel curve so i increased fuel psi to 42psi and it helped the problem but not solved. Only solution is to idle and only idle in no wake zone`s. Now that i`ve read your thread i`m going to try your fancy linkage on my tps. Makes sence to me.
    Thanks
    DB
  14. #119
    Jul 2007
    Hamilton Ohio
    Charlie,
    No matter how you slice it.............
    "You will be spending more time at the pump"
    When you consider that you've got (est.> 2.5 to 3 times) more incoming air than a OEM T/B can flow, well needless to say the only thing that will cover all that "FREE" air is expensive "FUEL"........
    I rest my case......see ya at the pumps Charlie, I know I'll be there.....
    Gary
  15. #120
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by Da Bull View Post
    Thanks
    DB
    DB,
    Thank you, it really shouldn't matter if your on the 2 ECU's vs. the single late model. The key is tricking the TPS into adding more fuel off idle and into the mid range. Like I told Charlie, you've got to cover that sudden off idle to mid range incoming air with lots of fuel. Think of using the TPS like an old Holley Carb accelerator pump, remember when you could change the pump cams on those, that's what has to be done w/the TPS, ya gotta get it to squirt more. Best of luck to ya......
    Gary
