Page 3 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 31 to 45 of 293
  1. #31
    Jan 2003
    aalsmeer
    Quote Originally Posted by Liberator*21 View Post
    300x injector plate w/injectors
    1" Composite spacer plate
    And last, the MAD Intake w/injector holes plugged
    in other words a long intake duct
    you sure you don,t want tot try ?
    Attached Thumbnails Attached Thumbnails gm3.8ltr_intake_a.JPG   gm3.8ltr_intake_b.JPG   gm3.8ltr_intake_c.JPG
  2. #32
    Jul 2007
    Hamilton Ohio
    Hey Ronnie,
    I get the gest of where your going with it, but where's the injectors in a long runner hi-torque intake like that ?????
    Gary
    Growing old is inevitable, growing up is optional.......
  3. #33
    Jan 2003
    aalsmeer
    mount something like this on top of the reed plate! ?
    custom plate maybe
  4. #34
    Jul 2007
    Hamilton Ohio
    Got'cha. It would be very cool to say the least.......
    Gary
  5. #35
    Jan 2003
    aalsmeer
    very hard without a measurement reference
    but it should be do-able
    anyway enough dreaming
    Attached Thumbnails Attached Thumbnails Schermafdruk van 2013-09-02 22:27:10.png   Schermafdruk van 2013-09-02 21:28:27.png
  6. #36
    Aug 2004
    Charleston, SC
    Liberator*21, on one hand I am reluctant to share too much info because I do not want to discourage you from trying something different. On the other hand, I hate to watch someone spend a pile of time & $$$ on something if my input might speed up your research or save you some dough. I'm no expert and can't explain the "why", but will share with you my experience with the MAD intake.
    In a nutshell, the main issue I had with it was that the motor could not be tuned to run well. My use was for a racing application and I used the injection mounts on the intake with custom injectors, and Merc Drag electronics. Tried pretty much everything possible as far as tuning the ecu and manipulating physical aspects of the bleed system & intake and the end result is that there is a significant fuel/air delivery disparity between the port & starboard banks. In the end, I thought of a few ways to address the issue but decided to use a different intake rather than continue trying to fix the MAD. 4 ways come to mind that might make it work properly: 1. Run an ecu that allows adjustment to individual cylinders, 2. Run different size injectors in one bank, 3. run 2 fuel rails & 2 separate fuel regulators, and 4. try relocating injectors (300x pate or mount like a drag motor to front half).
    The MAD might work fine for a lake motor, especially if individual cylinders can be tuned through the motorola ecu.
    Good luck with it and I'll stay tuned to your thread!
  7. #37
    Jul 2007
    Hamilton Ohio
    StratosVT,
    Rather then tell you my life's story here in this thread I'll send you a PM as to my background on this intake and others I've used/tried............thanks for your input and candor on the subject, it's always welcome.
    Gary
  8. #38
    Jul 2007
    Hamilton Ohio
    The current candidate, 1993 200 XRI VST in it OEM form:
    The pics below detail the mod that this VST went through, pretty much self explanatory. All 3 mounting ears were cut off. Bottom of tank had a fuel valve of some sort that I removed and drilled/tapped 1/4-18 NPT for the fuel out line to the EFI pump. Also cut off the 2 legs on the VST top that held the original pressure regulator. There was some sort of check valve inside the VST cover that was connected to the most fwd small top nipple (just below the needle seat when looking inside) this was drilled out and removed. The passages were also drilled out to max id's. this is now the the "Bleed Line Return" nipple. Most aft small top nipple will be the VST vent to atmosphere. The splash plate was removed to allow machining then reattached using 4-40 stainless screws. Only thing I've yet to do is remove the 5/16 fuel supply hose nipple and drill/tap to 1/8-27 NPT for an AN style fitting.
    Mounting plate is on the mill next.......
    Gary
  9. #39
    Jun 2010
    UK
    Interesting to see the atomisation of fuel problems with the MAD inlets. What ECU are you going to be using?
  10. #40
    Jul 2007
    Hamilton Ohio
    Currently going to start out with the OEM, making small changes one at a time, last thing I hope not to do is mod the ECU program (we'll see). I have the ability to adjust the TPS ratio vs Throttle opening which may compensate for some miss givings, as well as restricter plates made to restrict air and increase velocity, it's going to be a wait and see scenario and allot of testing over time. Theres no sense doing anything else until I've run out of tricks in my little black bag.................
    Gary
  11. #41
    Jul 2007
    Hamilton Ohio
    Morning update on progress:
    VST mounting plate done and mounted.
    Gary
  12. #42
    Jan 2003
    aalsmeer
    Currently going to start out with the OEM, making small changes one at a time, last thing I hope not to do is mod the ECU program .................
    if you get to this point without being able to work it out with the factory stuff
    a Mega-squirt MS3 might be an option
    i wrote the 60-6 crank wheel mod for the MS2
    http://www.msextra.com/forums/viewto...?f=125&t=50520
    but i was uncomfortable with the MS3 assembled code
    good news is they will officially add it
    just don,t know when
    they will speed things up if somebody is working on an engine
    you would then be able to use all your hardware without any modification ( flywheel tooth pattern, ignition coils , sensors )
    for your injectors you would have to wire ballast resistors or use the low impendance driver boards
    as the MS3X board does only high impendance injectors
    the MS3 would give you 6*6 3 dimensional tuning tables per injector
    at 645 $ this is a good option
    http://www.diyautotune.com/catalog/m...led-p-435.html
    water proof 1049 $
    http://www.diyautotune.com/catalog/m...nly-p-539.html
    Attached Thumbnails Attached Thumbnails Schermafdruk van 2013-09-05 18:41:02.png
  13. #43
    Jul 2007
    Hamilton Ohio
    Thanks Ronnie, I'll keep that as an option.
    Gary
  14. #44
    Jul 2007
    Hamilton Ohio
    Quote Originally Posted by 4JawChuck View Post
    Where did you get the plastic coated ball ends?
    Sorry, forgot to answer your question, it's the OEM TPS arm that I cut and threaded. If you need custom ball ends check out Mc Master Carr.
    Gary
  15. #45
    Jun 2004
    port st. lucie, fl
    looks great gary!! interestingly, i found the same thing w/ a big mixture distribution problem on an older style 3 litre w/ the mad intake, had to make the 1 side rich enough to live, and was never really rite. this was on the old style 3 litre/2 computer system. just keep an eye on the plugs/piston tops gary. dave just shipped the mad efi intake for my wolf engine, but i'm pretty bogged down in the gto project rite now.
