Page 20 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Results 286 to 293 of 293
  1. #286
    Shreveport, La.
    Ronnie, Here`s the thing. I ain`t that smart on electrics. I have read all of Charlie`s post`s as well as Gary`s and it may as well be written in French. I do thank you for the input tho.
    After my lil test and depending on how it goes my next step will be to remove all of the fuel and firing system and install a 260-drag type. I already have all the parts to make the 2.5 flywheel, stator, trigger bolt up. The biggest pain was to have a special hub made for the flywheel.
    I`m gonna bow out of Gary`s thread now because i think my original question has been answered,
    DB
  2. #287
    Jan 2003
    aalsmeer
    thought i try it again
    this is all you need
    6 times logic level output
    everything hooks right up
    and if you want a piece of custom code for that 60-6 crank wheel
    if that intake is a good idea ! that,s another story
  3. #288
    7 Post(s)
    anyone know where to get the individual injector hold down clamps as opposed the the Merc dual style ( custom inlet)?
    Many thanks
  4. #289
    Jun 2004
    port st. lucie, fl
    try to check kinsler's website
  5. #290
    7 Post(s)
    Quote Originally Posted by mrcrsr View Post
    good call but cant see them there
  6. #291
    Shreveport, La.
    Update on the Taylor three horn installed on a twin pack 300 ProMax. I sold all my 3.0L stuff but a bud went down the same road as me and I helped his with his setup. Concerning the flat spots I have some new info. Shaun Torrente down in Florida has come up with a little gizmo that's so simple it stinks. It simply advances the TPI ahead of the throttle blades by using a carb cam and both come to wide open throttle at the same time. Bottom line is that it solved the problem of flat spots all together. Amazing that something so simple is all it took. I think the cost was about $150 bucks.
    If I ever get another 300PM you can bet I will find a Taylor three horn because of the power it creates and install one of these little gizmo`s.
    DB
  7. Likes Liberator*21, baja200merk liked this post
  8. #292
    Mar 2006
    auckland new zealand
    do you have a pic?
  9. #293
    Shreveport, La.
    No but Shaun does.
