Results 136 to 150 of 293
10-09-2013, 07:34 AM #136
10-09-2013, 08:27 AM #137
10-09-2013, 02:56 PM #138
10-09-2013, 03:15 PM #139
150 will work just fine.
XR2001 & XB2002
10-09-2013, 06:34 PM #140
150 is where i have mine and i run on pump preimum (93 octain) with no issues.
DB
10-09-2013, 07:06 PM #141
Gary I thought you had high comp heads on that motor at one time?
10-10-2013, 03:05 AM #1425000 RPM
- Mar 2006
- auckland new zealand
- 655
- 9
- 13
what cc heads you running to get 150psi? what fuel psi you running?
10-10-2013, 04:12 AM #143
Dave,
Your correct Dave, I had a pair of MAD EFI Billet Heads, they were a "little" over 150'ish.......LOL !!!!!! I changed back to stock when I blew the motor last year on a load of bad fuel.
Grover,
I run premium 93/94 octane & Aces when on the road. I can't remember the exact cc's for 150 psi compression, Charlie would probably know.......
DB,
Did you do the linkage mod yet ??????? Report back when you, would like to have some feed back.
10-10-2013, 05:08 PM #144
I didn`t do a modification per say. I simply moved the tpi back against the movement of the throttle blade shaft. I didn`t put my DVA meter on it either. It did make a noticeable differance in the sound on the hose. Sounds "nasty". I`ll report more when i have time to take it to the lake as i`m in the middle of moving right now.
DB
10-10-2013, 05:16 PM #145
10-10-2013, 11:51 PM #146
Yep, Thats what i ment. I can relate this to installing a larger cam in a hot rod or going to larger jets in a carb. At least at idle anyway. I don`t know what effect it will have at top end or even cruise speed. I didn`t have any problems in those area`s. We`ll see.
DB
10-11-2013, 06:34 AM #147
memory serves correct 60-61 cc yields 150 psi w/ a 300x factory piston, i'd have to check my notes to be sure
10-11-2013, 06:35 PM #148
Update to where I'm heading next......IAT Sensor;
I've placed a micro switch activated by the TPS arm that will be sending a switchable signal to the ECU/PCM. Normal IAT signal during normal running, but a changed ITA signal at WOT. The signal change is in resistance, I'm able to trick the ECM/PCM at WOT that the air temp is 32 degrees, this signals the ECU/PCM to add additional fuel to compensate for the very cold temp signal its getting. Another benefit to this is a little timing bump as well, the additional fuel amounts to a 10% increase. Here's my mock and up as always, its a work in progress situation:
10-11-2013, 08:47 PM #149
Gary just thinking out loud but a lot of what your doing might be fixed buy just going to bigger injectors??? Just a thought.
10-12-2013, 04:02 AM #150
Dave,
Thanks for the suggestion, I'm kinda looking at it like this, I'm going to try everything I can without having to lay out some serious cash. As much as the thought of bigger injectors sounds right for WOT, it may really screw up the idle to mid range. It's very obvious that the issue here is lack of fuel since I've now got an abundance of air available. Under my current setup, I'm not that far away from getting it right as I'm running great till the motor hits a wall in the low 80's.
I got an email from a buddy and he recommended a "Piggy Back" controller system may help. All these ideas are great but there each about $500 a pop with no guarantee of success. What I'm doing is also a great learning experience for me as EFI is still relatively new to me and I'm learning on the fly and besides I'm having fun doing it. Boating days are becoming limited here as winter draws ever closer so I'll continue on my present path and then we'll see what next year has in store.
