Results 1 to 7 of 7
Thread: Lithium ion starting batterys
07-10-2013, 06:30 AM #1
Any guys using lithium ion batterys for rec useage? I wanna use them in my sand bar drag boat but dont wanna have starting issues. My blue optima has done a great job so far! Also should i get a 800cca lithium because my blue top is? Is anybody using lithium moto brand?
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
07-10-2013, 11:04 AM #2
I have been using them for about a year now and they are amazingly strong and light but I would be hesitant using them in a lake boat. Keeping a charge in them is critical, I can get 30 starts out of them with a 280 and 200 psi compression. After that they need a good charge.
A optima weighs 45lbs a standard 24 series batt is under 40.Chet Olson
07-10-2013, 11:10 AM #3
Someone told me that they have a charger for the lithium batterys that runs off of the electricity the outboard creates. i have heard tournament guys able to go days without having to plug in.
1984 17vee Bullet w/1985 Johnson 150gt (bob's nose cone, hydrodynamics custom 8in. jackplate, custom skid plate and foil, and 26p trophy plus) currently 70mph tournament loaded.
07-10-2013, 12:35 PM #4Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,705
- 117
- 85
- 771
I use a 24 cell battery from Rich Srnec and get between 30 and 50 starts on high compression. Antigravity offers a 24 cell that looks nice also. I've done the 16 cell Ballistic and they'll work but the extra 8 cells is only a an extra pound and makes a big difference. The power from a lithium is also more stable during running. My voltage only drops about a tenth of a volt during a pass, much better for the ecu. When I ran standard Braille batteries I had to run a dedicated ecu battery because of the voltage drop during a pass from the trim. Lithium allowed me to do away with it
Erik Kiser
07-10-2013, 08:52 PM #5
Question is whats knocking 35 pounds off my rig gona do for me preformance wise? I know every bit helps but like what kinda gain can i expect? Im somewhere around 1150 to 1200 range now without me in the boat
07-10-2013, 09:22 PM #6
25 pounds is measureable in 1320 if you have the means to measure it accurately.
[SIGPIC][/SIGPIC]
07-11-2013, 07:18 PM #7
All little things add up
