Results 1 to 5 of 5
06-30-2013, 09:52 PM #1
bit of metal on lower unit drain plug
is it acceptable to have a little metal on the drain plug on the lower i just changed my oil an there was a little bit of fine graphite like stuck to the plug. no shards or pieces
79 Baja 18ss merc 2.5
94 trophy 2352 (sold)
85 checkmate enchanter merc 2.5
07-01-2013, 12:09 PM #2
cool deal i didnt change the oil for some time till now, how much in an out play should there be on the prop shaft
07-02-2013, 01:12 AM #3
There is no real spec on propshaft end play. On most of them, there is no thrust shim anyway so there is not much you can do about it. I set my lower with the thrust ring up at .020". The ones without the ring will have anywhere from .020" to .060" from what I've seen. If it's way too loose, it could be a worn thrust surface on the shaft. That would be very uncommon.
The Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
07-02-2013, 08:11 AM #4
yea figure at most it is a 1/4 inch at most not grinding or slipping its good
07-02-2013, 08:12 PM #5The Reverend, (Cedar Machine Service on Facebook)
1977 Viper
