Results 1 to 15 of 29
    Apr 2011
    Corinth, MS
    What years were 2.4 & 2.5 blocks built by Mercury?
    I need a history lesson.....trying to settle an argument. What years were the 2.4 made, and when did they switch to 2.5?
    Thanks.......
    1992 Bullet 20XRD -- 1995 Mercury 2.5 225 ProMax, JC’s nose-cone lower unit, 26 pitch Trophy, 10" Rapid Jack, 85mph @ 1/2” above pad (still tweaking)
    Sep 2006
    Key Largo, Fl
    First 2.4 was in 1978,first 2.5 in 1991,Chris
    Apr 2011
    Corinth, MS
    Quote Originally Posted by Chris Carson's Marine View Post
    Thanks Chris! But I guess I just lost the argument......our newly acquired Mariner Mag II is a '91. My dad looked up a voltage regulator by serial # on marineparts.com, which said it was for a 2.5 liter. I thought this motor was a 2.4 liter. Got it running correctly today by replacing both switch boxes, but tach is still jumping around & it's not charging. The voltage regulator (danged water-cooled.....$$$) didn't ohm right, so now we've got to decide if we want to buy a new water-cooled one, or change the stator & go to a dual regulator system.
    shreveport,la
    My guess is that's a 2.4 Fatblock
    Erik Kiser
    Sep 2006
    Key Largo, Fl
    I probably have a used water cooled one if you want to go that way around 200$,guaranteed good,Chris
    Apr 2011
    Corinth, MS
    Thanks! I don't remember the exact part # on this one, but I do know it ends in A13....I'll talk to him & get in touch with you. What's your phone number?
    Apr 2011
    Corinth, MS
    Chris, I went over & did some more trouble-shooting today. The stator is fine & so is the reg/rectifier. I pulled the main wiring plug apart & spread all the pins, put it back together, & tach is working perfectly. It's putting a steady 13.3 volts to the battery at idle, too, so it appears to be charging correctly. Thanks for the help! If/when I DO need a reg/rec, I'll give you a call!
    Apr 2011
    Corinth, MS
    Quote Originally Posted by patchesII View Post
    I'd still like to know which block this is. How can I tell if this is a 2.4, 2.4 Fatblock, or a 2.5?
    Oct 2003
    Albany NY
    Post pictures!
    Apr 2011
    Corinth, MS
    Quote Originally Posted by kingsbiship View Post
    Post pictures!
    I'm not close to the boat right now…
    TX......somewhere?
    '91 Mag II is a 2.4 fat block. Same as XR4 water cooled reg and all. '91 was a "stupid year" with a mixture of 2.0, 2.4 and 2.5 blocks that all looked tha same with exception of tha 200 2.5. 7 petal front..............Was most definitely tha last year of tha 2.4 even if it "looked like" a 2.5.......
  12. #12
    Ft. Lauderdale, Fl
    If it'a a '91 fatblock, pulling the heads is the best way to see if it's a 2.4 or 2.5. 2.4 fat block and 2.5's have dowel pins to align the heads..... 2.4 cylinder has a bore of 3 3/8" and the 2.5 is 3 1/2", from the outside, they look the same .... there was a thread on here not too long ago where someone sold a 2.4 fatblock as a 2.5, they are easy to mix up.........
  13. #13
    Apr 2011
    Corinth, MS
    OK, thanks! That's the reply I was looking for. Now the obvious question: What gave the fat block its name? 2.4 block with bigger bores, or what?!
  14. #14
    Apr 2011
    Corinth, MS
    Quote Originally Posted by flabum1017 View Post
    You were typing while I was.....we had to put one head on it when we got it. Had a crack (actually a casting flaw) that was letting water into one cylinder. It definitely had dowels, but I didn't measure the bores. You have, however, told me how to tell for sure, so thanks!
  15. #15
    Ft. Lauderdale, Fl
    A 2.4 fat block is a 2.5 block with 2.4 cylinders in it.......
