Results 1 to 4 of 4
05-30-2013, 02:18 PM #15000 RPM
- Sep 2012
- kentucky
- 199
tweaking the allison xb2003 for speeds over 100+
Has anyone modified or removed the lip on the pad on an xb2003
Has anyone removed the wind shield. just needing good advice before i start to modifying. my current set up is a stock lip and im running 14.5 on motor setback and pad height varies from 1/2 inch to 1 1/2 inches above pad. motor is a 2.5 drag with 25cc heads which run about 180lb cylinder pressure. 15inch mid. and 1:87gears in the sportmaster. props are 26 hoss chopper and 28 alley cut chopper. thanks for any advice on the lip modifycation and windshield removal and any other good advice...
05-30-2013, 02:31 PM #26000 RPM
- Jackson,Tenn.
- 1,691
I would not remove the lip. I remember Darris showing me some info he had from his testing and best I can remember the windshield was designed for some down force. This was a lot of years ago (20 maybe) and my memory is not always that great. He did convince me to leave the widshield on for drag racing.
Hopefull there is some one more current on the windshield info.Ray Neudecker Over The Hill Gang Outboard Racing
05-30-2013, 02:35 PM #3
Have you run it over 100 with the current setup? If so, what don't you like? There are plenty of guys over on the Allison page that have sanded on the lip with some good and some not so good results. Varying heights, to none at all. There are also size differences from the factory depending on the year. I believe the newer years 96 or 98 + have larger lips than mid to early 90's.
Shouldn't have any problem running well over 100 with the current setup. 1 1/2" above is getting a little high, but with 14.5" of set back, may not be too bad. A good 260/280 is 104-105 in a 2003 bass boat, with the right setup.
allisonowners.com (if you haven't been there yet.)
2006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
06-02-2013, 04:05 PM #4Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
Had a 1997 XB2003 with a 260 on it. 1/2" above pad on a 14.5" plate. Coned CLE and a Hoss Hyperdrive 29" prop. Cant remember diameter. A about 90 mph you could really feel the nose start to drop due to all the down force on the console/windshield. I was trimming the heck out of it to get it to release and really get up on the pad. Jim Barnes was there that day and said to take the windshield off. Did that. Went from 97gps to 99.5 gps. Old motor was blowing by pretty bad and always figured the boat had 101-102 in it with that set up. My advice would be to not screw around with the lip!!!
