Results 16 to 30 of 56
Thread: Increasing Looper Compression
05-10-2013, 02:23 AM #16
05-10-2013, 02:47 AM #17
This is what I'm considering using. It seems to be suitable for the job and might be easier to use than a liquid epoxy.
http://www.jbweld.com/product/j-b-highheat/
thanks Craig
05-10-2013, 05:38 AM #18
I used JB Weld rebasing some headlight bulbs a few years back and though they get pretty hot they held up fine.
I was going so slow I almost crashed. - JamesGang
1978 24 Superboat - 250 EFI
05-10-2013, 06:56 AM #19
AGAIN... Do not cut the heads if you dont have to. Your engine calls for the thick gaskets 88-92. When you pull the heads to plug the reliefs put thin gaskets from 93-up loopers on it. We gained about 15psi on an old wore out looper by plugging the reliefs and going from thick to thin gaskets.
Kevin
05-10-2013, 09:19 AM #20
05-10-2013, 09:24 AM #21
That will probably work as long as you can get it to seal to the sides of the idle relief hole. FWIW, I took some stuff like that one time, wadded it up, and stuck it on the side of a cinderblock wall. I believe the block would have broke off if I beat on the wad of the stuff. It was hard as a rock.
It will flat mess up a ring I bet, so just go slow, be careful, and make sure none is in the bore or protruding out of the idle relief hole. In fact I'd try to pack it into the hole a little bit, so you don't have to worry about it being to close to the bore.
And yes, the marine tex epoxy was a challenge. It was alot like working with silicon caulk.
05-11-2013, 12:06 AM #22
Thanks guys for the advise. I now have a plan to work to over the winter months here.. Roll on the spring. Cheers Craig
05-11-2013, 10:24 AM #23
05-11-2013, 12:07 PM #24
Plain soap and water with remove most any epoxy before it hardens. Works great for smoothing out MarineTex.
05-30-2013, 08:48 PM #25Junior Member
- Mar 2010
- AR
- 9
Does anyone have the part # for the thin gaskets?
05-30-2013, 08:59 PM #26
05-30-2013, 09:04 PM #27
05-30-2013, 09:15 PM #28
Nevermind, looks like a superseded number for the same part.
05-31-2013, 07:33 AM #29Junior Member
- Mar 2010
- AR
- 9
Thanks!
06-01-2013, 06:07 AM #30
Thanks Kevin, I'll go down the path of the relief holes first. Is there any problems with fitting a closed deck head gasket 93-up to an open deck motor? Will it have any effect on cooling water flow into the head? I seem to recall Racer saying once to stick to the gasket that suited the block.
Craig
