Results 1 to 3 of 3
Thread: 83 Bullet Rebuild Update
05-01-2013, 05:04 PM #15000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
I think I'm about ready to start back together with this. Just a couple of questions. The pixs showing the light spots where I was too aggressive with the hull. Do you think that I would be OK coring over these and repairing the gel of course from the outside? The other thing is the sanding has produced high and low spots. Would I be OK coring with a generous amount of resin or should I mix some putty and smooth the spots out similar to finishing sheetrock. Thanks
05-04-2013, 11:07 AM #2
If you core with balsa and use cabisil it will fill in a lot of that, unless it went thru to outside then I would back glass it.
2004 DYNA T/C 95 dyno 90hp
1976 Ventura 200 Prostock
06-02-2013, 10:10 PM #35000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
I've glassed over the worst of it with 1708 and a layer of 1208
