Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Jul 2014
    pa
    Yeah I figured. Just be doing same side
  2. #17
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by daytrader View Post
    Depending what clamp bracket u have, the bracket that holds the second tube for the second cable might be longer then the standard one. I have the single trim ram offshore style clamp bracket and when I couldnt find that bracket I made one out of flat stock. I have a new one for the "standard" clamp bracket if u need one.
    Mercury 92876A8 should get you pointed in the right direction. The bracket that daytrader mentions may not be correct in that kit, but as he says, it is pretty simple to fab from flat stock. There are sevral on ebay right now in the $60-$90 range.
    If you prefer to scrounge, you can pull that stuff off any make outboard and fab the same bracket mentioned to fit your clamp.
  3. #18
    Jul 2014
    pa
    Thank you very much I've never seen any of these before so I think it's going to be easier to wrap my head around it once I actually see one
  4. #19
    Dec 2011
    Ottawa
    I have a dual rack rideguide with 16 ft. Cables, came out of my ae-21 working fine,i sold boxes of ride guide helms and motor attachments on here last year, they go like hotcakes
