Results 1 to 5 of 5
    Jun 2011
    Prt St Lucie Florida
    Gaffrig tach wiring ?
    Got a used Gaffrig monster Tach that I installed. The back of the gauge has red/ ign, blk/grd, grn/sender, wht/ light, then 2 looped wires. The sticker says for a 6 cy snip the brown wire. I have it hooked up to a 2.5 outboard. The RPMs are way wrong!! The old gauge worked with the engine and wireing... So, is there something I did worng with this monster tach wireing or is the tach just junk???? Its acting like its set for a four stroke, but I see no way to change anything no prob settings
    Thanks for any help,
    Dan
    St. Pete Fl
    did you already cut the wire? You don't setup a 2 stroke outboard the same as a 4 stroke v6. you should set it up for 12 pole.
    Jul 2011
    Chesapeake, VA
    Saw same thing with my Livorsi tach's, they used dip switches, but I had to set it to "12 cylinder" for them to read correctly for my 300xs's...
    Hope that helps
    Jan 2015
    Miami
    Quote Originally Posted by gorillapowered View Post
    Dan
    how did you do to work perfectly? I got the same problem but I don’t find how set it up right ! Twin 300X
    Attached Thumbnails Attached Thumbnails A1D2FEF7-508D-4166-8D90-431413CAF6C7.jpeg   7BB121F7-342E-485E-9D2C-13690C531D99.png
    northern IL
    6 pole setting worked on my Stewart Warner Gauge on my 2.5 has dip switches.
