Results 1 to 9 of 9
Thread: 22 Activator Set Up Help
03-18-2013, 05:33 PM #1Member
- Nov 2012
- new york
- 87
I have a 2007 Activator with 2006 250xs merc, bought came with 14inch Bobs jack plate, question? is the 14 to big for the southshore of long island, being rough or is it good. Also what prop to use?
03-18-2013, 05:52 PM #2Banned
- Jun 2009
- Done
- 771
- 51
- 101
- 113
post pics did you run it yet if yes how did it run rpm speed feed back will help
03-18-2013, 05:58 PM #3Member
- Nov 2012
- new york
- 87
what r u running on your progression, prop and plate?
03-18-2013, 06:53 PM #4Banned
- Jun 2009
- Done
- 771
- 51
- 101
- 113
12 bobs and pro et and eagle et its larrys old boat
03-19-2013, 11:47 AM #5
I know your boat but have never been in it or seen it run. Your bottom is corrected and no notch now which is better with your motor. You first must get it balanced right w/setback to fly without porpoise at high speeds. You could try a 4 blade also for more overall lift and see it that helps carry straight before you try reducing setback.(trophy plus, Bravo I, pro et or turbo TXP ot4) If that does not help go down in setback. A 10" manual jack plate might be a good place to start. The TXP 3 you have is a fast prop but it likes to run high so start at 3/4" above and go up from there. You must get that sporty up or you'll never get great speeds. Perhaps you already have these ideas. You may have to make other changes........how close or far apart are your front seats? Battery placement in rear or under deck?
Keep us informed along the way.....good luck !
Let us know how you make out.1990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
03-19-2013, 11:51 AM #6Member
- Nov 2012
- new york
- 87
Hi dnelson,
I am going to put a 10 inch bobs on it, I have the 14inch now but its really not practical on the southshore of long island, the back of the boat hangs low, going with a 4blade pro et, and take it from there. the battery is in the back of the boat, should I move it forward, or run ht eboat after the changes?
03-19-2013, 12:01 PM #7
I would run it first and make changes after testing. Record what you do and the effects as you go. I know someone that might want the 14" if you decide to sell it.
03-19-2013, 12:12 PM #8Member
- Nov 2012
- new york
- 87
I ran it with the 14inch , to much hopping and the guy i bought it from had 4 sand bags in the front, weight of 200 pds, I think the 14 is to big for this boat and would rather start at with the 10 inch and go from there. But if someone wants the 14inch, its just the plate, no pump
03-19-2013, 12:26 PM #91990 22' Activator Yami HPDI 300-sold-86.4
