Results 1 to 3 of 3
02-05-2013, 08:10 AM #1Member
- Dec 2009
- New brunswick Canada
- 66
Low range engine bog 30/40hp mercury
The motor is a 2003 30/40hp mercury! When I pull out hard from a dead stop my motor will bog right down and shut off! If I feather the throttle it won't shut off! Once I pull out, my motor works beautiful through mid range and wide open! I have a set of boyseen reeds installed as well! Anybody know what might be causing this!! Thank you!-
02-05-2013, 09:11 AM #2
If you have a low speed idle needle try turning it out a 1/4 turn to richen it up . May just need the carb cleaned ,especially if it sits unused over the winter . If that fails try raising the float very slitely to richen it up. Glen
02-05-2013, 09:13 AM #3Member
- Dec 2009
- 66
Thank you ill try that!
