Results 1 to 8 of 8
Thread: registering a California boat
01-05-2013, 03:10 PM #1Junior Member
- Oct 2010
- massachusetts
- 18
I have bought a Rayson from a guy in Ca. I have the title, but I need to know what is the HIN to go by. On the title there is a "vessel number" and also a "CF number". Since there are no markings on the hull that I have found, which number do I use? The boat is now in Massachusetts.
01-06-2013, 10:09 AM #2
if you cant find the HIN , its not to big a deal in mass so long as the bill of sale and title match , the enviro police will issue the boat a new MASS HIN # .
01-06-2013, 02:40 PM #3Junior Member
- Oct 2010
- massachusetts
- 18
I just have a title for the boat. I need to know which number on the Ca title is the one that was issued to the boat.
01-06-2013, 02:44 PM #45000 RPM
- Jan 2003
- LA, CA
- 454
- 7
Not the cf # use the vessel number
01-06-2013, 04:23 PM #5
depending on the year of the boat the environmental police usually need a rubbing of the actual HIN# that is molded into the hull of the boat . i believe its 1973 or newer that requires the # rubbing , if its older than 1973 the MASS EP will issue your boat a new hin # regardless of what number your title has . ( just been down that road , its not a big deal ) they will issue you a new title with the new HIN# and HIN stickers to apply to the top right corner of the transom and one to hide somewhere else in the boat .
02-11-2013, 11:08 PM #6Member
- Jul 2008
- Fallbrook CA
- 40
Hello
The early Rayson Craft ###s were on the port stringer foreward of the foot board bulkhead. They were usually stamped in a metal plate that was on the stringer under the fiberglas. The letter would indicate the mold and then the hull ###. Usually 3 numbers.
HARLAN ORRIN
02-12-2013, 09:40 AM #7Junior Member
- Oct 2010
- massachusetts
- 18
02-24-2013, 08:55 PM #85000 RPM
- Oct 2007
- Los Angeles
- 133
(.......if its older than 1973 the MASS EP will issue your boat a new hin # regardless of what number your title has . they will issue you a new title with the new HIN# and HIN stickers to apply .....)[/QUOTE]
Just my opinion, this practice is ridiculous, just an example of the people in the State government finding a way to make money. If you already own a boat, and it obviously has a hull # already, we should be able to transfer that hull # to another states registration if that is the owner's residence. It's against Federal Law to change a car's VIN, boats should be no different. Likewise, when you buy your first car, you should be issued a license plate, that stays with you. When you buy a new car, you should just transfer your old plate to the new vehicle. I know that's how license plates work in Boise, Idaho. Here in California, you lose your plate with the car, and they charge you for a new plate.....again. So, back to the boat HIN, that # should be THE number used forever when transfering title.
Makes sense to me, but then again, common sense is lost on our Federal and State Governments today.
