Page 264 of 271 FirstFirst ... 164 214 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 LastLast
Results 3,946 to 3,960 of 4052
  1. #3946
    Jan 2018
    Not a tourist in Forida anymore.
ID:	506777I’ll even throw in the patio Umbrella, amd the matching chairs.
  2. Likes scott reierson liked this post
  3. #3947
    Jul 2004
    Connecticut
    Great shot of the Labsport 21 GTR hull bottom. 22 degree pad bottom V that runs stainless steel inserts on the pad bevel. Also has electric drop down ballast tank fill. 40 gallons in the bow fills in 1 minute and empties in 30 seconds. Hull designed from scratch "down under" and now yet another one is here in the US. Have to appreciate shops like Labsport and Tuff and others for designing new stuff in the SOB range. Labsport routinely cranks it in rough water (with photos) and sometimes in air only. Running 96 mph with the 300R V8.
    Attached Thumbnails Attached Thumbnails Labsport21KeelDesign.jpg   1.jpg   Labsport21 Interior1.jpg   236496967_4342758295767766_3248191950913522836_n.jpg
  4. Likes JDChase, 28SkaterCa. liked this post
  5. #3948
    Jul 2004
    Connecticut
    Steering on the Labsport for the 300R V8 Tallboy
    Attached Thumbnails Attached Thumbnails Team222Labsport21300R.jpg   Labsport21V8Kryptonite23400.JPG
  6. #3949
    Jul 2004
    Connecticut
    Quote Originally Posted by 2.5-21 View Post
    Will they ever produce actual weight of this new boat? Those speeds need a sub 800 pound boat!
    Quote Originally Posted by David View Post
    It’s probably a light version, but I don't think it would have to be less then 800 lb to go 105.
    The old Tuff 21 (22 degree deadrise and 7'7" beam) weighed 946 lbs (bare hull) and the old Tuff 21 that set "The List" record of 105 weighed 890 lbs.
    I'd bet that the Tuff 20 demo boat is 800 lbs or less given there design changes. Should be a great match with the new 3.4 V6 for sure.
  7. #3950
    Jul 2004
    Connecticut
    The one that started all the fun back in the day ............
  8. Likes NICE PAIR liked this post
  9. #3951
    Jan 2021
    Lake Muskoka,Ontario
    The old Tuff 21 (22 degree deadrise and 7'7" beam) weighed 946 lbs (bare hull) and the Tuff 21 that set "The List" record of 105 weighed 890 lbs.
    Ran with them on W.E.-said all carbon 20 was 535/550 lb.!
  10. #3952
    Jul 2004
    Connecticut
    Quote Originally Posted by Muskoka2 View Post
    Fugh .............Say that weight number again?
  11. Likes NICE PAIR liked this post
  12. #3953
    Jan 2021
    The above but normal lay-up would be 800+-just guessing!
  13. Thanks scott reierson thanked for this post
  14. #3954
    Jul 2007
    Delray Beach
    Quote Originally Posted by RBT View Post
    That statement is pure fiction. If you use the challenger 21 as reference, this is longer narrower and deeper, just because it’s fast doesn’t negate it from rough water.
    You seem to get so offended by the suggestion that the boat may not be the best in rough water, which in fact it isn't by design. Mark and Thomas would say as much. Sure, they could build it heavier, changing the dynamics of the hull, now it wouldn't be nearly as fast but be better in rough water, depending on the weight dynamics.
    As most of the Tuff's sit, they are exceptional straight line performers, design with tons of rear bias CG, huge notch, wide pad, ultra light etc. That's great, I actually love that.
    But, a Chaudron 22 or a Nitra 22 will destroy every boat on here in rough water and it's not even close. The reason? They have 24 and 26 degree deadrise, 6' and 5.5' beams, and run flatter, with more running surface. It's just physics. You don't have to take it personally. The Chaudron and especially the Nitra have shortcomings with their designs too, they will never be the fastest. The Nitra is so narrow and the deadrise is so steep that it will roll on its side easily and have weird handling, it's a tiny boat and barely goes over 90 with a 300R. The Chaudron is only slightly faster and has a less extreme design and is more in the middle.
    Personally, I'm more of a lake boat guy and I love the Allisons and Tuffs. Obviously the Tuff 20 is bigger than a SS, GS or XR Allison. But the Allisons and Tuffs on a lake, even with a little lake chop will be vastly faster than the Nitra, Chaudron, Progression and OG Challenger, obviously.
    Simply believing a hull is the fastest and also the best in rough water, defies physics and is not true. Is it possible a heavier Tuff 20 can compete with some of the boats on the list, maybe, but that would change the dynamics drastically from the design.
    Rough water narrow beam advantage
    Too much rear bias weight in a light hull?
    Heavy
    Single OB offshore racing, Chaudron
  15. #3955
    Feb 2005
    Muskoka Canada
    I’m offended by ignorance.
    All things being equal, a challenger 21 vs a Tuff 21 equal weight same setup is a dead heat. The Tuff 20 with mass added to equal the above 21 will be better. To your point deeper vee and narrower/longer. What people are forgetting is this thread is about the fastest, Tuff 24 is the far and away winner. The 20 is second. As mentioned, mark and Thomas set up for lake running, that’s not to say the design won’t run in the rough.
    I do agree that Nitra and Chaudron being deeper and narrower will eat the entire list in the ocean, not the question that started this thread.
    further, only the Nitra and Chaudron, (they are just as light as Tuff) are building modern laminate boats. Badass, the rest are resin buckets. (Progression, is in the middle as far as laminate)
    I feel like this thread is like watching CNN
    2023 TUFF 25
  16. #3956
    Jul 2004
    Connecticut
    Quote Originally Posted by JDChase View Post
    To my knowledge, no one has hung a 300R on one either, very exciting to see how it plays out, but theoretically, it should be just what I want. I will certainly keep everyone posted.
    Agree ...... Will be interesting for sure with the first 300 R.
    I believe Malta said the 22 footer clocked 95mph in lake like water with a 300XS so a very easy spot up on "The List" given how many photos there are of Chaudron's running in rough water unlike some.
    Attached Thumbnails Attached Thumbnails Chaudron Pro22Keel300XS.JPG   Chaudron22 LineUp.JPG   Chaudron22.png   Untitled.jpg
  17. Thanks JDChase thanked for this post
    Likes JDChase, blacktruck liked this post
  18. #3957
    Jul 2019
    Tennessee
    RBT and Blacktruck, I enjoyed both your posts, you both sort of said the same things, no need for name calling, lets leave that for the FB losers. Yes this is about the fastest SOB but, in what conditions so I think it's all relative. Thank you both.
  19. Likes blacktruck liked this post
  20. #3958
    Jul 2004
    Connecticut
    Velocity still alive and kicking all these years later .......
    Attached Thumbnails Attached Thumbnails Velocity22Merc300R.JPG   OldVelocity.JPG   VelocityUS300XSSolid.JPG   NewVelocity230SCSide.JPG
  21. #3959
    Feb 2005
    Muskoka Canada
    One of the great designs that stands the test of time. Fantastic boat to drive!!!
    2023 TUFF 25
  22. Likes blacktruck, Ziemer liked this post
  23. #3960
    Jul 2007
    Delray Beach
    We're basically saying the same thing, lol. Although the Challenger would be slower, because of the pad width and notch even if they weighed the same. (lift / CG)
    But generally SOB is like Class 7, up to 22' Arbitrary as it might be. If the rules are broken, then ya the Allison XR is easily the fastest, then maybe the 20 Tuff.
    If you've never run in the ocean, I don't think you'd understand how different it is.
    I'm not the biggest Progression fan but for a hull that can run in the rough, it is also very fast. It might be dated looking but might be among the best all around in all conditions given the constraints, or maybe the Chaudron. A Chaudron 22 weighs 1,700 lbs without power. So more than double the weight of a Tuff 20?
    It's all good. The "who would win in a fight Bruce Lee or Spiderman" arguments are really lame. Just get on the water and enjoy.
  24. Likes JDChase, Grant Conklin liked this post
