Results 2,866 to 2,880 of 4052
Thread: Fastest SOB hull???
07-03-2018, 07:06 AM #2866
07-03-2018, 07:15 AM #2867Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-07-2018, 08:19 AM #2868Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
The List as of 4th of July Holiday week. Time to stock up on 300XS mota's ............
Fastest SOB Hulls Available For Purchase New In 2018....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
#1 Tuff 21 kevlar hull-890lbs – 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad -- Confirmed 105.9MPH Driver Blake Sewell Canada
#2 Bernico F2 21 standard hull-727lbs–21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad -- Confirmed 98.1MPH Driver Dave Van Steelant (550lb s3000 385hp 103.1)
#3 Progression 22 standard hull-948lbs – 22’1”Long, 7’8” Beam - 24 degree variable deadrise + 7" pad -- Confirmed 94MPH Driver goneby
#4 Sutphen 21 standard hull-1325lbs–20’9” Long, 7’2”Beam - 20 degree variable deadrise + 3" pad -- Assumed 88MPH Driver Unknown (525 I/O heavy layup ran GPS 93.4)
#5 Nordic Crossfire 21 & SR-21 standard hull-1475lbs – 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad -- Confirmed 86MPH Driver wildone
#6 ________________Open Slot for 2018
And the fastest of the no longer produced hulls....with power noted
#1 2002 Intimidator 21 -- Deadrise=22 Degrees + 6" pad. Confirmed 104.6MPH – Stock Merc 15” 300X(325HP) - Driver Trimmed Out15
#2 1985 Velocity 22 Stepp “Old Style Deck” -- Deadrise=22 Degrees + 12" pad. Confirmed 97.1MPH – Stock Merc 20" 300X(325HP)- Driver B kNo023
#3 1986 Superboat 21 Classic -- Deadrise=22 Degrees + 6" pad. 97MPH - Stock Merc 20” 300X(325HP)- Driver hoser
#4 1976 Challenger 21 -- Hull 1350lbs Deadrise=21.5 Degrees. Confirmed 90MPH - Yamaha 250HPDI Phase III (326HP) - Driver Jamescole
#5 1990 Activator 21 -- Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad. Confirmed 84MPH – Stock Yamaha250 Ox66 (256HP) - Driver dnelson964
#6 2012 Velocity US 220 -- Hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad. Confirmed 83.5MPH – Merc 300XS - Driver aaronmt73
whipper liked this post
07-07-2018, 04:42 PM #2869
07-07-2018, 04:50 PM #2870
So now with the new 300 being a V8 and there are now higher HP motors available that will work on a SOB hull shouldn't the SOB power include up to the 400R? The 300xs is no longer in production so something in the rules for this thread must change as well correct? In the Currently in production part of it? Not that a 400R will be faster than the new 300 V8 on some hulls that remains to be seen.
07-07-2018, 04:54 PM #28715000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
AZMIDLYF liked this post
07-07-2018, 10:18 PM #2872Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Yep, this is the last year for the 300XS. That said, I only know of one rough water SOB in the US that has one of the new motors on it so there isn't much to track just yet and I don't think there will be for a couple of years. I hope I am wrong and they start to pop up.
07-08-2018, 09:55 AM #28735000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
07-08-2018, 03:38 PM #2874
Thats what I was thinking. The 24Tuff SOB with a 400r might be a very fast setup for top end.
07-08-2018, 11:47 PM #2875Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
There is a 400 running currently on one of Laveycrafts 21 XCS's out West. I think the weight would be fine as many of the rough water SOB's in the group have been rigged with twin 2.5s over the years.
07-09-2018, 08:03 AM #2876
There is a Velocity with a 400R also Right? I thought the owner posted a video on here a while back
07-09-2018, 10:33 AM #2877
07-09-2018, 10:35 AM #2878
07-09-2018, 01:23 PM #2879
Yes the force 21X has been running the 400r and also the big Verados on there 21,s. i love Force boats they have the sickest interiors also!!
07-09-2018, 02:09 PM #2880Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
That V7 with the 400 is running 84-85mph with a plush interior. 28SkaterCA here on the site has the same hull he imported new into the US. The Velocity V7's have 22 degrees a deadrise. I do not believe he has taken any top speed stats with his 300XS yet but I suspect Craig would easily take the open 6th slot with it.
