Results 2,056 to 2,070 of 4052
Thread: Fastest SOB hull???
01-13-2014, 09:28 PM #2056
01-13-2014, 10:56 PM #2057
01-14-2014, 08:12 AM #2058
Yeah since my snowbird location is only about 2 miles from his shop I try to stay on top of the situation. Now if he would just stop screwing with these dragsters and stick to the task at hand
01-14-2014, 08:18 AM #2059
01-29-2014, 11:51 PM #2060Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Bump it up for frozen Florida, ice choked Islip, and can't run fast in CT
02-06-2014, 10:30 AM #2061
Maybe we have to re-name this thread to something more like: "Fastest SOB - without down riggers."
1992 Progression 22
Mercury Racing 250R
02-06-2014, 02:11 PM #2062
I'd either break or sink a bass boat in our water even on a good day. Doesn't count!
02-06-2014, 06:59 PM #2063
02-07-2014, 09:15 AM #2064
Yeah of course I appreciate that, but the point is that any of the boats on the list at the moment are proven boats in rough ocean water. A bass boat would fall apart or be swamped pretty quickly! A Superboat or Challenger with massive setback that runs 90+ would probably run like crap in rough water, but the set up could be changed to cope. Bassboats are made for going fast on flat water and for fishing off, not for waves!
seychellesboy liked this post
02-07-2014, 12:01 PM #2065Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
A Bass boat while cool for other reasons would not be able to manage any type of reasonably high speeds in rougher waters where all of the hulls being discussed here spend 75% of there time. Start a bass boat thread and that Stroker flatbottom will be hard to top on a river run or lake. I'm not sure if Kurt is from Florida or not but that motor is very unique. I looked at one out of Florida a few years ago I believe for my kid brother.
02-16-2014, 09:51 PM #2066Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Adding the Tuff 21 pad width ..........
Fastest SOB Hulls Available For Purchase New In 2014....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
#1 Tuff 21 kevlar hull-890lbs – 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad (Confirmed 102.5MPH Driver Blake Sewell) (2002 Tuff 21 ran 102MPH w/300X)
#2 Bernico F2 21 standard hull-727lbs–21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad (Confirmed 98.1MPH Driver VanSteelant) (550lb s3000 385HP ran 103.1MPH)
#3 Progression 22 standard hull-948lbs – 22’1”Long, 7’8” Beam - 24 degree variable deadrise + 7" pad (Confirmed 94MPH Driver goneby)
#4 Sutphen 21 standard hull-1325lbs–20’9” Long, 7’2” Beam - 20 degree variable deadrise + 3" pad (88MPH Driver Unknown) (525I/O with heavy layup ran GPS 93.4MPH)
#5 Nordic Crossfire-21 or SR-21 standard hull-1475lbs– 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad (Confirmed 86MPH Driver wildone)
#6 Velocity 220 standard hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad (Confirmed 84.8MPH Driver aaronmt73)
And the fastest of the no longer produced hulls....with power noted
#1 1986 Superboat 21 Classic Deadrise=22 Degrees + 6" pad (Confirmed 97MPH -Stock Merc 300X(325HP)- Driver hoser)
#2 1985 Velocity 22 Stepp “Old Style Deck” Deadrise=22 Degrees + 12" pad (Confirmed 95MPH– Stock Merc 300X(325HP)- Driver B kNo023)
#3 1976 Challenger 21 - Hull 1350lbs Deadrise=21.5 Degrees (Confirmed 90MPH - Yamaha 250HPDI Phase III (326HP) - Driver Jamescole)
#4 2007 Intimidator 21 Deadrise=22 Degrees + 6" pad (Confirmed 85MPH - Stock Yamaha 250 Ox66 (256HP) - Driver Hydropimp911)
#5 1990 Activator 21 - Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad (Confirmed 84MPH – Stock Yamaha250 Ox66 (256HP) - Driver dnelson964)
#6 2005 Kryptonite 22 Custom - Hull 1500lbs Deadrise=23 Degrees (Confirmed 79.9MPH - Stock Merc Promax(285HP)- Driver ghost28)<o</oLast edited by Greg G; 02-21-2014 at 10:21 AM.
02-22-2014, 01:46 PM #2067Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
TTT for the first 50 degree day in CT and thoughts of Summer!
03-05-2014, 12:56 PM #2068
03-24-2014, 01:59 PM #2069Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Just get out your checkbook and you can have any color you want rev ............ https://www.youtube.com/watch?v=-RsjzjKDZss#t=20
07-23-2014, 09:38 PM #2070Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Yep.......updating "The List" with current GPS data on the Sutphen 21 SSX. I'm now wondering if my 88mph assumption with a 300XS and Sporty is possible when the Sutphen 21 is
laying down 73.4mph with the Merc 225hp fishin motor in the real world. Can this Sutphen hull pick up 15 mph with the 3.2 stroker motor or will the left coast Nordic SR-21 move up to #4.
#1 1986 Superboat 21 Classic Deadrise=22 Degrees + 6" pad (Confirmed 97MPH - Stock Merc 300X(325HP)- Driver hoser)
#2 1985 Velocity 22 Stepp “Old Style Deck” Deadrise=22 Degrees + 12" pad (Confirmed 95MPH – Stock Merc 300X(325HP)- Driver B kNo023)
</oLast edited by Greg G; 07-23-2014 at 10:15 PM.
