    Sep 2013
    long island
    From 92-95 is a ton of work from 92-100 is almost impossible
    11757 btw lol
  2. #2657
    Jul 2004
    Connecticut
    Quote Originally Posted by 28SkaterCa. View Post
    The Lavey started with a 2.5 then Verado 350 and now 400. Its not F-2 legal but they can run age group and Catalina. We run together often.
    Interesting series of motors, thanks for the intel. That is a pretty substantial boat to have a 2.5 280 on the back pushing it. Would be very interesting to know what speeds it pulled with that motor.
  3. #2658
    Jul 2004
    Connecticut
    Quote Originally Posted by wickedwitthestix View Post
    Tend to agree with you but his Velocity V7 has a bare hull weight of 682lbs so you never know. I believe the Canada Tuff weighs 890lbs
  4. Likes Capt.Insane-o liked this post
  5. #2659
    Feb 2005
    Muskoka Canada
    890 bare
    2023 TUFF 25
  6. Thanks Greg G thanked for this post
  7. #2660
    ...Great running boats...(click on the top yellow bar for full-size image)
  8. Thanks Greg G thanked for this post
  9. #2661
    Jul 2004
    Connecticut
    Polar Vortex got you down?
    Pissed at Bombogenesis and burst pipes?
    Why clench your fists when you can buy a boat that's made "The List"
  10. #2662
    Jul 2004
    Connecticut
    B
    ecause 2018 has arrived, and "The List" still tells no lies............
    Fastest SOB Hulls Available For Purchase New In 2018....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
    #1 Tuff 21 kevlar hull-890lbs – 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad
    Confirmed 105.9MPH Driver
    Blake Sewell Canada
    #2 Bernico F2 21 standard hull-727lbs–21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad -- Confirmed 98.1MPH Driver Dave Van Steelant (550lb s3000 385hp 103.1)
    #3 Progression 22 standard hull-948lbs – 22’1”Long, 7’8” Beam - 24 degree variable deadrise + 7" pad -- Confirmed 94MPH Driver goneby
    #4 Sutphen 21 standard hull-1325lbs–20’9” Long, 7’2”Beam - 20 degree variable deadrise + 3" pad -- Assumed 88MPH Driver Unknown (525 I/O heavy layup ran GPS 93.4)
    #5 Nordic Crossfire 21 & SR-21 standard hull-1475lbs – 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad -- Confirmed 86MPH Driver wildone
    And the fastest of the no longer produced hulls....with power noted below
    #1 2002 Intimidator 21 -- Deadrise=22 Degrees + 6" pad. Confirmed 100MPH – Stock Merc 15” 300X(325HP) - Driver Trimmed Out15
    #2 1986 Superboat 21 Classic -- Deadrise=22 Degrees + 6" pad. Confirmed 97MPH - Stock Merc 20” 300X(325HP)- Driver hoser
    #3 1985 Velocity 22 Stepp -- “Old Style Deck” Deadrise=22 Degrees + 12" pad. Confirmed 95MPH – Stock Merc 300X(325HP)- Driver B kNo023
    #4 1976 Challenger 21 -- Hull 1350lbs Deadrise=21.5 Degrees. Confirmed 90MPH - Yamaha 250HPDI Phase III (326HP) - Driver Jamescole
    #5 2012 Velocity US 220 -- Hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad. Confirmed 84.8MPH – Merc 300XS - Driver aaronmt73
    #6 1990 Activator 21 -- Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad. Confirmed 84MPH – Stock Yamaha250 Ox66 (256HP) - Driver dnelson964
  11. #2663
    Just saw that Predator Powerboats purchased the Intimidator molds and will be building some 21s that might break onto this list.
  12. Likes noli, Trimmed Out15, tux974 liked this post
  13. #2664
    Jul 2004
    Connecticut
    Outstanding news, the 6th slot is open and waiting in 2018
  14. #2665
    Boat pictured ran right at 100 with the X so an XS should not be too far off.
  15. Likes Greg G liked this post
  16. #2666
    Jul 2004
    Connecticut
    Build it and they will come
  17. #2667
    Funny, the European hulls are generally much narrower than the U.S. versions. The Bernicos, Phantoms, Chaudrons, Graunners, etc, run small beams.
  18. Likes powerabout liked this post
  19. #2668
    I agree and the construction methods will be improved on from past methods as well.
  20. #2669
    Feb 2005
    Muskoka Canada
    The Tuff 24 is narrower too, I also expect it to be at the top of this list this year by a significant margin
    2023 TUFF 25
  21. Likes tux974 liked this post
  22. #2670
    Quote Originally Posted by RBT View Post
    I agree on both points.
Page 178 of 271 FirstFirst ... 78 128 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 228 ... LastLast
