Page 17 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 241 to 255 of 292
  1. #241
    Jul 2004
    Connecticut
    If I recall, the rare Offshore Promax came with a 1 piece from the factory for 1 or maybe 2 years. Some will know exactly. I had so many problems with my 1 piece I finally threw it in a homemade blast furnace and turned it into ingots. Seriously, if you have any swings in water temps, forget the 1 piece IMO. Variables, are simply not a 1 piece's friend IMO.
    Popey thanks for the posts and the info. I think you have yours sorted nicely.
  2. Likes Capt.Insane-o liked this post
  3. #242
    TX......somewhere?
    Quote Originally Posted by Go Time View Post
    225 Promaxes also came with 15” (offshore) mids and one piece adapters. (poppet and t-stats)
  4. #243
    Jul 2004
    Connecticut
    In 20" Promax motors the only one with a 1 piece was the Offshore model.
    I guess I should have looked at my own post from a couple years back lol
    Attached Thumbnails Attached Thumbnails PromaxDriveshaft Housing (Offshore) (1).pdf
  5. Likes Capt.Insane-o liked this post
  6. #244
    Belgium
    I had to drill a small hole in the water inlet part of the adapter. The part of the adapter where the copper tube fits in too.
    The 2 piece plate has a small hole in the same area. This did the trick on mine. Without doing it still ran colder as with the 2pc plate.
    I made a video of my dash when running with the 2pc plate and the 1pc and it's just about the same. It took me a lot of testing but very happy I got it 100% right.
    I use the water pump base with the small weep hole.
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  7. Likes moby27 liked this post
  8. #245
    Jun 2001
    Cromwell. NEW ZEALAND
    I am sorry.the 225 promax did come available as a 15 inch and one piece exhaust, only the alien cowl models though. The base plate part number is the same for both one and two piece plates. Only the 15 inch 225X has a unique number. Would explain confusion on promax models cooling system.
    Popey
  9. Likes tux974 liked this post
  10. #246
    Jun 2001
    Lower cowl mounting plate...
    Part numbers 225X short 849480t2
    225 15 and 20 inch with alien cowl 849480t
    Popey
  11. #247
    Nov 2015
    Atlanta Texas
ID:	468720Click image for larger version.
ID:	468721I know this is an old post but This is what i saw on my 225x short shaft when i pulled the power head last night. Maybe it will help someone. It has 120 degree thermostats and a poppit valve.
  12. Thanks Greg G, bigboy thanked for this post
  13. #248
    Sep 2017
    Ashland city tn
    So promax did have a 1piece plate with stats and poppet , man never know what the hell mother merc would do to these things. Theres another thread goin that could use this post in it.
  14. #249
    TX......somewhere?
    Quote Originally Posted by Merc 2.5 View Post
    pretty sure it was tha 15" only.... think all tha 20's were 2 piece.....
  15. Thanks Merc 2.5 thanked for this post
  16. #250
    Correct 15" only and the popet does nothing with a 1pc.
  17. #251
    TX......somewhere?
    Quote Originally Posted by tux974 View Post
    thought tha 15" PM one piece was different and had a "functional" poppet???.. reason it shows in parts???
    i can't say as i've never seen that particular plate???
  18. #252
    Nov 2015
    Atlanta Texas
    Yes sir , the poppit functions normally on this one. i had to replace it about a year ago.
  19. #253
    Aug 2006
    GA
    Steve Pope. I did a 260 on a Land & sea 2.4 one piece. Worked fine & still working
  20. #254
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Mrzip View Post
    260 is nik bores, pro max is steel. apples and oranges. no issues putting a 2.5 motor that came off a 1 pc plate on a 2.4 1 pc plate. dump holes are usually a better size on the 2.4 plates. 2 pc plate motor on a 1 pc plate is a different story...
  21. #255
    Belgium
    Look at the stainless base plate in the cowl. Its all closed except at the popet area. This is how merc made it work... mount the wrong pan and you are in trouble.
    Fletcher 17F6
    Hydrostream HST 20F
  22. Likes Ramm2012 liked this post
