Results 136 to 150 of 292
07-17-2017, 03:09 PM #136
07-17-2017, 03:37 PM #137
So Pete you would ignore the fact that it runs cold at idle / non plane speeds.
I think the 2 piece plate blocks of some water when entering the adapter. But than again at idle the cooling circuit should be almost closed. Next time i will plug the dump lines of the stats. The bleed holes will make up the drain holes in the plate. If no difference in temp there still should be something differrent with the 2 piece cooling system.
07-17-2017, 03:39 PM #138
07-17-2017, 04:03 PM #139
07-17-2017, 04:09 PM #140
I would definitely want that corrected, you don't want to hammer the gas on an ice cold motor. I was referring to higher speed operation. You're getting good temp so I wouldn't mess with the poppet opening because if you make it larger you're just going to dump more water and make it colder.
07-17-2017, 04:16 PM #141
Try plugging one of the dump holes in the plate. As for the steam like Bunnymeister said..close off the idle reliefs and poke some holes in your block off plate. If you could open it up and sandwich some stainless mesh to dull the noise would be an option too.
07-17-2017, 04:32 PM #142
You have any idea what would happen when all closed off lynn?
07-17-2017, 06:06 PM #143
Capt.Insane-o liked this post
07-17-2017, 07:23 PM #144
07-17-2017, 08:56 PM #145Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
It might help to get a bit better frame of reference overall. Some questions include do you boat all year round? If not, and you break the boating season in Belgium into 6 month slots like I do here in CT, what is the swing in sea water temperatures coming into your motor over those 6 months? Cold at idle is one temp at month 1 and another temp at month 6. What is your actual "cold" at idle temp now in July?
07-18-2017, 10:28 AM #146
Hi,
I now what you are trying to say. And you are right it may be good now but not anymore in april or october. To be honest i just want it right and fixed. It cannot be that hard but it seems it is.
Temps were just fine with the 2 piece. Only thing I changed is the adapter. I think the differences between both plates are:
- 2 piece plate water flows in but has a drain of 3,5mm which enters in the water retour cavity. So basicaly there is a loss of water that flows through the cylinders.
- on the 1 piece adapter there are two drains of 2,8mm. The drains are in the water retour so water gets drained after it went through the cylinders.
- 2 piece plate has a passage that goes to the back of the plate to cool the tuner. This is only when popet is opened. So i think this has nothing to do with my problem.
So basicaly if you want to make the cooling between both adapter as close as possible than I think it should be better to block the drains in adapter. 2 small holes should be drilled in the wall that divides the water entry cavity and the water retour cavity....
07-18-2017, 11:21 AM #147
I think it's time to get scientific and start measuring actual temps with an IR gun or other method, not graduations on the dash gauge. Also, I don't recall any pressure readings which will give clues to what that thing is doing.
07-18-2017, 11:32 AM #148
Wow this is become very interesting. Subscribed for end results.
Pete, I like the scientific idea.....
07-18-2017, 12:21 PM #149
I think there maybe some restriction with the gasket in between the upper and lower plate of the 2 pc. The gasket blocks the inlet passage except for 2 ~3\8" holes ....do you think this might have an effect. My gut says no, but then....
What is the water temperature where you are running, what is water press at idle and WOT?Go Time
26 Regulator twin 250 EFI
07-18-2017, 12:33 PM #150
