Results 241 to 255 of 292
03-13-2019, 06:48 AM #241Screaming And Flying!
- Jul 2004
- Connecticut
- 6,006
- 464
- 168
- 910
- 951
If I recall, the rare Offshore Promax came with a 1 piece from the factory for 1 or maybe 2 years. Some will know exactly. I had so many problems with my 1 piece I finally threw it in a homemade blast furnace and turned it into ingots. Seriously, if you have any swings in water temps, forget the 1 piece IMO. Variables, are simply not a 1 piece's friend IMO.
Popey thanks for the posts and the info. I think you have yours sorted nicely.
Capt.Insane-o liked this post
03-13-2019, 08:40 AM #242
03-13-2019, 08:51 AM #243Screaming And Flying!
- Jul 2004
- Connecticut
- 6,006
- 464
- 168
- 910
- 951
03-14-2019, 03:52 PM #244
I had to drill a small hole in the water inlet part of the adapter. The part of the adapter where the copper tube fits in too.
The 2 piece plate has a small hole in the same area. This did the trick on mine. Without doing it still ran colder as with the 2pc plate.
I made a video of my dash when running with the 2pc plate and the 1pc and it's just about the same. It took me a lot of testing but very happy I got it 100% right.
I use the water pump base with the small weep hole.
moby27 liked this post
03-14-2019, 06:48 PM #245
I am sorry.the 225 promax did come available as a 15 inch and one piece exhaust, only the alien cowl models though. The base plate part number is the same for both one and two piece plates. Only the 15 inch 225X has a unique number. Would explain confusion on promax models cooling system.
Popey
tux974 liked this post
03-14-2019, 06:56 PM #246
Lower cowl mounting plate...
Part numbers 225X short 849480t2
225 15 and 20 inch with alien cowl 849480tPopey
07-02-2020, 09:14 AM #247Junior Member
- Nov 2015
- Atlanta Texas
- 20
07-02-2020, 05:14 PM #248
So promax did have a 1piece plate with stats and poppet , man never know what the hell mother merc would do to these things. Theres another thread goin that could use this post in it.
07-02-2020, 07:27 PM #249
07-03-2020, 04:43 AM #250
Correct 15" only and the popet does nothing with a 1pc.
07-03-2020, 06:17 AM #251
07-13-2020, 09:52 AM #252Junior Member
- Nov 2015
- Atlanta Texas
- 20
Yes sir , the poppit functions normally on this one. i had to replace it about a year ago.
07-13-2020, 07:42 PM #2535000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Steve Pope. I did a 260 on a Land & sea 2.4 one piece. Worked fine & still working
07-13-2020, 08:13 PM #254
07-14-2020, 12:28 AM #255
Look at the stainless base plate in the cowl. Its all closed except at the popet area. This is how merc made it work... mount the wrong pan and you are in trouble.
Ramm2012 liked this post
