Results 1 to 2 of 2
Thread: best way to plumb twin tanks?
11-24-2012, 03:33 PM #1Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 308
- 6 Post(s)
sorry, posted this to wrong thread. thought i deleted it.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
12-13-2012, 11:11 AM #2New Member
- Dec 2012
- fsdddd
Just recently switched from a 25" 3.0 Merc 225 Opti, w/ dual pickup lower to a 20" Merc 2.4 carb. w/ CLE lower. When I switched it over I dropped it around 3 to 3.5" from where it was w/ the 25" shaft. Running a 26 bullet cut chopper and it takes of and runs pretty well (turning it right @ around 5600-5800). Just don't have any bow lift. Has good water pressure, just wondering if I need to continue dropping it or maybe raise it? Whats a good starting point to get this thing set up right?Just recently switched from a 25" 3.0 Merc 225 Opti, w/ dual pickup lower to a 20" Merc 2.4 carb. w/ CLE lower. When I switched it over I dropped it around 3 to 3.5" from where it was w/ the 25" shaft. Running a 26 bullet cut chopper and it takes of and runs pretty well (turning it right @ around 5600-5800). Just don't have any bow lift. Has good water pressure, just wondering if I need to continue dropping it or maybe raise it? Whats a good starting point to get this thing set up right?Just recently switched from a 25" 3.0 Merc 225 Opti, w/ dual pickup lower to a 20" Merc 2.4 carb. w/ CLE lower. When I switched it over I dropped it around 3 to 3.5" from where it was w/ the 25" shaft. Running a 26 bullet cut chopper and it takes of and runs pretty well (turning it right @ around 5600-5800). Just don't have any bow lift. Has good water pressure, just wondering if I need to continue dropping it or maybe raise it? Whats a good starting point to get this thing set up right?
pass4sure.com http://pass4sure.com/
southsmoke.com http://www.southsmoke.com
646-364 http://www.pass4sure.com/646-364.html
security+ certification http://www.pass4sure.com/CompTIA-Security-plus.html
642-832 http://www.pass4sure.com/642-832.html
640-553 http://www.pass4sure.com/640-553.html
640-822 http://www.pass4sure.com/640-822.html
PMI-001 http://www.pass4sure.com/PMI-001.html
642-437 http://www.pass4sure.com/642-437.htmlLast edited by jimmyjack; 05-25-2013 at 12:13 AM.
