Page 9 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 121 to 135 of 300
Thread: Viper resto-mod
  1. #121
    Nov 2003
    With the limited deck and cockpit space, the gps antenna will be mounted under the deck. Epoxied some wooden pads to screw the antenna base to. I think it will be better than the adhesive tape they provided with the kit and keeps things serviceable. Since the deck is inverted, went ahead and cut out the splashwell for the lower jackplate bolts.
    Attached Thumbnails Attached Thumbnails DSCF4685 (Copy).JPG   DSCF4688 (Copy).JPG
  2. #122
    Nov 2003
    Should look good around the new 2" stainless steel tube adaptors I got off this site. The boat is going to be painted orange/white, hence the orange tubing.
  3. #123
    Aug 2012
    beaumont, tx
    its fun collecting all your rigging and hardware.....looking good.
  4. #124
    Apr 2011
    Northcentral WI
    Wow, Jackplate does look very nice. I have a feeling my hydraulic one has quit on me. Only problem is mine is a 3" plate, not sure I want a 6" plate.
  5. #125
    Nov 2003
    Picked this up on the site for my Merc. Needed a little work, so it was priced right, especially knowing the snout that got cut off wasn't discarded.
    Attached Thumbnails Attached Thumbnails offshore (Copy).jpg   offshore1 (Copy).jpg
  6. #126
    Nov 2003
    Welded the snout back on to the mid to "tone" it down a bit. Now waiting on some zinc chromate and some phantom black paint.
    Attached Thumbnails Attached Thumbnails DSCF4703 (Copy).JPG   DSCF4706 (Copy).JPG
  7. #127
    Nov 2003
    Still progressing on the Viper. Getting the dash components all mocked up before reattaching the deck to the hull. Almost have the inner hull sanded and ready for paint too.
    Attached Thumbnails Attached Thumbnails DSCF4709 (Copy).JPG   DSCF4710 (Copy).JPG
  8. #128
    Aug 2010
    BURLINGTON WI
    Nice work
  9. #129
    Nov 2003
    While waiting for paint for the mid, decided to mock it up on the transom and check the propshaft/jackplate heights. The swivel bracket is mounted to the jackplate at the second holes from the bottom. With the propshaft level with the pad, there's still 1.5" of upward travel and 2.5" of downward travel.
    Attached Thumbnails Attached Thumbnails DSCF4713 (Copy).JPG   DSCF4715 (Copy).JPG
  10. #130
    Nov 2003
    Made a template for an aluminum dragplate. Will pick up some 3/8th. inch t-606 aluminum next week.
  11. #131
    Sep 2009
    iowa
    Lookin good! Looks like that extra tall transom really helped with engine height.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  12. #132
    Australia
    Quote Originally Posted by proprider View Post
    Cav plate extensions can put a lot of leverage on the cav plate. If they are too strong the casting can crack. Better to have the plate light enough that it bends if loaded too much. 1/4 inch is more than enough. We have been making larger plates than yours for a long time and we only use 1/8 aluminium. I have seen the casting crack from a ski rope caught in the prop and pulling against the drag plate. I got a 1/2 inch parasailing rope around the prop once, with a 1/8 plate and it just bent the plate. Hey... 13000 flights, sooner or lately your going to run over the rope ... lol. From staff getting their jollies jumping waves. And from staff backing into the garage and bumping the back wall.
  13. #133
    Nov 2003
    I meant to say 3/16th, but you make a good point. I'll go with the 1/8th. Thanks for the tip!
    Quote Originally Posted by GregAdams View Post
  14. #134
    Australia
    You are welcome . I thought 3/8 was a bit of overkill I hope you are going to post some video when she hits the water. I have been following your rebuild and you are going to have a very unique boat.
  15. #135
    Apr 2002
    Wrong Irand, NY
    I like the gussets you glassed to the dash by the steering wheel.
    nice work all around
    Formula 260ss 496HO
    Bender Clan Member
