Page 7 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 91 to 105 of 300
Thread: Viper resto-mod
  1. #91
    Sep 2009
    iowa
    http://www.kleen-ritecorp.com/c-1079-2-diameter.aspx
    Here is a link to the vacuum hose thats in multiple colors. I think thats what you were looking for.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  2. Likes NY Switzer-Head liked this post
  3. #92
    Nov 2003
    That's the site, thank you
    Quote Originally Posted by NosBoss View Post
  4. #93
    Nov 2003
    Glassed in the mounting bulkheads for the rod holders. One side was done first to make sure the mounting position worked well for quick retrieval from the drivers seat. The other side will get done next and it will hold the rear light mast. They tuck up well and out of the way.
    Attached Thumbnails Attached Thumbnails DSCF4598 (Copy).JPG   DSCF4604 (Copy).JPG   DSCF4606 (Copy).JPG
  5. #94
    Nov 2003
    The drivers kill was mounted in the center of the drivers seat. Should allow for some unrestrictive movement at the helm and will be attached at the hip area. Pretty sure the passenger kill will be mounted the same.
  6. #95
    Nov 2003
    I already had some trim switches for the steering wheel spokes and was trying to decide where to have the trim and jackplate cords come through the dash. Did a little shopping on the net and came up with a set of these instead. Now that I have them and attached, headin to the machine shop to make a hub for the helm.
    Attached Thumbnails Attached Thumbnails DSCF4610 (Copy).JPG   DSCF4612 (Copy).JPG   DSCF4615 (Copy).JPG
  7. #96
    Nov 2003
    Knew I was going to have to deal with the lower jackplate bolts being higher than stock, and according to Murphy's Law, they would be right in the way of the splashwell. Needed about 2" of clearance to get the washer and nut on the mounting bolt. Looked around and found this nice cup in the laundry room. Measured 2.5" deep so it got cut in half and glasses to the splashwell, The underside will get cut out the next time the deck is off.
    Attached Thumbnails Attached Thumbnails DSCF4621 (Copy).JPG   DSCF4632 (Copy).JPG
  8. #97
    Kawarthas
    Thanks for all the detail. Going to start redoing mine this winter and going to use a lot of your ideas. Should be one cool boat.
  9. #98
    Ontario, Peterborough
    Glad we could help out. LOL
    Looks like something I would do.
    1994 16' Murphy 1991 115 Merc
    1985 12' Charger 1989 70 Merc
    1981 18'DL Charger 1989 200EFI Merc
  10. #99
    Nov 2003
    Got the fuel delivery worked out. The 2 - 6 gallon portable tanks will be strapped to the saddles with detachable fuel lines. Both tanks are connected to a "T" fitting that feeds the primer bulb/fuel filter/engine. The primer bulb was mounted for quick access from the cockpit.
    Attached Thumbnails Attached Thumbnails DSCF4626 (Copy).JPG   DSCF4627 (Copy).JPG   DSCF4631 (Copy).JPG
  11. #100
    Nov 2003
    Since the transom is drilled, and most of the aft rigging laid out, decided to trim the motorboard down. Transitioned it into the deck fairing and should look pretty cool when it all gets glassed in.
    Attached Thumbnails Attached Thumbnails DSCF4633 (Copy).JPG   DSCF4636 (Copy).JPG
  12. #101
    Nov 2003
    You're welcome, happy to share. I've had the finished boat in my mind for some time, but since getting started, this thing is evolving into something even better. I very much look forward to mashing that gas pedal and haggin on when it's finished!!
    Quote Originally Posted by Fast Viper View Post
  13. #102
    Nov 2003
    I'll take that as a compliment
    Quote Originally Posted by Murph View Post
  14. #103
    Nov 2003
    Since there is no real subfloor in the hull, got to thinking about any water that would accumulate from getting in/out of the boat, or wet gear, backwash over the splashwell, etc... and where it was going to go if a quick slowdown were to happen. Most of the lowest part of the hull is the pad area and most of it is already boxed in and should reduce a lot of "splash". Decided to add a baffle in the bilge area that is open at the bottom to help somewhat contain the accumulated water.
    Attached Thumbnails Attached Thumbnails DSCF4638 (Copy).JPG   DSCF4639 (Copy).JPG
  15. #104
    Nov 2003
    Decided to add a small 600gph bilge pump that will be manually operated from the helm. The hose will be routed through the highest point to help reduce any water intake through the exit port when not in operation...maybe.
    Attached Thumbnails Attached Thumbnails DSCF4648 (Copy).JPG   DSCF4653 (Copy).JPG   DSCF4646 (Copy).JPG
  16. #105
    Nov 2003
    Looked at many photos of Vipers sitting in the water with big motors to see where the best spot for the exit port of the pump. This spot looked to be the best. If it doesn't work, I'll just glass it up and find another.
    Attached Thumbnails Attached Thumbnails DSCF4654 (Copy).JPG   DSCF4641 (Copy).JPG   DSCF4650 (Copy).JPG
