Page 6 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 76 to 90 of 300
Thread: Viper resto-mod
  1. #76
    Nov 2003
    All the "chassis" work is completed. Finishing up by added some additional cloth/resin on the sides of the chine where you would step into the hull. After that will be the sanding process again and paint. There will be about 3" of the top edge left unpainted for glassing the deck back on.
    Attached Thumbnails Attached Thumbnails DSCF4515 (Copy).JPG   DSCF4518 (Copy).JPG   DSCF4521 (Copy).JPG
  2. #77
    Fantastic work.
  3. #78
    Nov 2003
    Thank you sir!
    Fantastic work.
  4. #79
    Apr 2002
    Wrong Irand, NY
    Really like the detail.
    Well done!
    Formula 260ss 496HO
    Bender Clan Member
  5. #80
    Aug 2012
    beaumont, tx
    Fantastic work.
    YOU GOT SKILLS.................im still taking notes
  6. #81
    Nov 2003
    Found another advantage to splitting the deck/hull apart. While working on the foot throttle, tucked under the steering and dash, kept banging my back and head. Realized all I had to do was move the deck forward to get better access. I'm a regular student at the school-of-hard-knocks...
    Attached Thumbnails Attached Thumbnails DSCF4558 (Copy).JPG   DSCF4559 (Copy).JPG
  7. #82
    Nov 2003
    Needed to figure out the throttle and shifter cable lengths, so the engine was mocked up to get the prop shaft near the pad. Got it fairly close and checked to see if there would be enough travel in the jackplate to get the prop shaft high enough. Sure glad there was additional height added to the motorboard as there will be no problem getting above the pad.
    Attached Thumbnails Attached Thumbnails DSCF4565 (Copy).JPG   DSCF4568 (Copy).JPG
  8. #83
    Ontario, Peterborough
    Your Better then me.
    I would probably think about it, then forget to do it. LOL
    Do everything twice, then you know you got it right.
    1994 16' Murphy 1991 115 Merc
    1985 12' Charger 1989 70 Merc
    1981 18'DL Charger 1989 200EFI Merc
  9. #84
    Nov 2003
    Laid out the routing for the throttle and shifter cables. Glassing in some looms to run them through along the outer stringer. Wouldn't want anyone to get a foot caught up if they decided to bail out of the hull. Pair of 2" holes were cut into the splashwell also and have a set of 2" tube adapters on their way
    Attached Thumbnails Attached Thumbnails DSCF4574 (Copy).JPG   DSCF4577 (Copy).JPG   DSCF4571 (Copy).JPG
  10. #85
    Sep 2009
    iowa
    I really enjoy looking and reading your build thread. I got a couple ideas from it, too bad it was a little late. Lol. I'm wishing i would have built my transom higher like yours cause i think its going to be difficult to get my pro shaft high enough on my ventura.
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  11. #86
    Nov 2003
    One of the Merc cables that I had worked out for the throttle. Looking for another that measures 10ft. between the two 3/4" barrel fittings at each end. Anybody have one their not using? It will be used for the shifter cable as it sets back further.
  12. #87
    Nov 2003
    Glad to share the experience. I have a 73 Vega drag car that I have been building and a mentor explained to me that you build the car, then take it apart, then do the finish work, then put it all back together, then go and test it. I'm taking the same approach with this build.
    Quote Originally Posted by NosBoss View Post
  13. #88
    Nov 2003
    Received the 2" hose adapters today and got them mocked up. Measured what length of hose was needed and will start looking. A while back, someone posted a link to a site that had a lot of different colors of hose. Couldn't find it when 2" flexible hose/tubing was googled.
    Attached Thumbnails Attached Thumbnails DSCF4581 (Copy).JPG   DSCF4585 (Copy).JPG
  14. #89
    Nov 2003
    When a question was asked about cleats of a Viper, it was mentioned to install them in the splashwell. That's where they went and decided to use the "wrap" type versus a "T" type. One less thing to get hung up on if quickly exiting the boat! Mocked up the light/base so wiring can be laid out.
    Attached Thumbnails Attached Thumbnails DSCF4583 (Copy).JPG   DSCF4579 (Copy).JPG
  15. #90
    Nov 2003
    Found these multi purpose rod holders in the sporting goods dept. Made some wooden bulkheads to glass along the right and left inside chines. They will be located near the drivers seat, paddle and push/pull pole on one side and the rear light post on the other. The Velcro wraps make for quick & easy access.
    Attached Thumbnails Attached Thumbnails DSCF4589 (Copy).JPG   DSCF4596 (Copy).JPG
