Page 4 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 46 to 60 of 300
Thread: Viper resto-mod
  1. #46
    Nov 2003
    Drilled my first virgin.......transom that is!
  2. #47
    Shreveport, La.
    LOL! Good one.
    DB
  3. #48
    Ontario, Peterborough
    WOW, Multiple Times too. LOL
    1994 16' Murphy 1991 115 Merc
    1985 12' Charger 1989 70 Merc
    1981 18'DL Charger 1989 200EFI Merc
  4. #49
    Nov 2003
    McHenry,IL
    www.bottomsupboatrepair.com
    847-
    587-5553
    Complete Service Center
  5. #50
    Nov 2003
    Used some left over plywood to make a battery tray/hold down for the Optima battery. Glassed some wing mounts to the stringers so the tray could be bolted down. The 6" stringers will support the weight of the battery.
    Attached Thumbnails Attached Thumbnails DSCF4433 (Copy).JPG   DSCF4436 (Copy).JPG
  6. #51
    Nov 2003
    Glassed in the bulkheads for the seats and shifter. After some thought, the center stringers got boxed in at the seats. At a 5.5" i.d., couldn't help but to think if one lost their balance while standing up, and your foot was between those stringers, pretty sure it would be.....snap goes the ankle. Boxing them in, along with bolting down the battery tray, could also help triangulate the center pad area.
    The nice grain of the okume wood will be left visible when finished.
    Attached Thumbnails Attached Thumbnails DSCF4437 (Copy).JPG   DSCF4439 (Copy).JPG   DSCF4442 (Copy).JPG   DSCF4444 (Copy).JPG
  7. #52
    Nov 2003
    The deck was set back on to check for foot throttle and foot pad placement before glassing them in. Now that the seat bulkheads are in place, rigging mock-up can get started. The way that the throttle and support are set up now, feels real comfortable when at the helm......real comfortable!
    Attached Thumbnails Attached Thumbnails DSCF4446 (Copy).JPG   DSCF4448 (Copy).JPG
  8. #53
    Nov 2003
    More tools at the helm.
    Attached Thumbnails Attached Thumbnails DSCF4451 (Copy).JPG   DSCF4458 (Copy).JPG
  9. #54
    Nov 2003
    Set up dual tanks so the capacity could be 12 gallons. Both 6 gallon tanks will be plumbed into a central fuel rail that will feed the Merc. The fuel rail will be centrally mounted below the height of the tank pickups, allowing the two tanks to hopefully self level.
  10. #55
    Nov 2003
    Battery fits nice behind the rear seat and the terminals are under the splashwell. The rear seat will be hinged at the front so it can be tilted forward, to access the battery and bilge.
    Attached Thumbnails Attached Thumbnails DSCF4457 (Copy).JPG   DSCF4461 (Copy).JPG
  11. #56
    Nov 2003
    When the deck gets glassed back on to the hull, the raised motorboard will be trimmed in a way that will follow the original lines, only extended a little. The bulkhead that was added to support the stringers, worked out well as a ledge for the splashwell to mount to and support. A little tweeking and it should nest in there well.
    Attached Thumbnails Attached Thumbnails DSCF4467 (Copy).JPG   DSCF4469 (Copy).JPG   DSCF4471 (Copy).JPG
  12. #57
    Nov 2003
    Some profile pics of the mock-up.
    Attached Thumbnails Attached Thumbnails DSCF4472 (Copy).JPG   DSCF4475 (Copy).JPG   DSCF4462 (Copy).JPG
  13. #58
    Great Progress, Sweet looking job.
  14. #59
    Nov 2003
    Thank you, it's been an enjoyable project.
    Quote Originally Posted by Murph View Post
  15. #60
    Kawarthas
    Looking good , you have some great ideas and always look for to your next post . Keep 'em coming.
