Results 16 to 30 of 300
Thread: Viper resto-mod
11-22-2012, 09:19 AM #16
hi proprider
Nice work
I noticed the stringers too. Ginge is correct. Those stringers would be better if they were scarphed. 30 degrees is not enough taper. That is closer to a butt joint than a scarph. You should be looking at a taper of 8:1 for your scarphs. i.e. if the ply is 20 mm thick your taper should be 160 mm long.
All is not lost though. Put "fibreglass butt straps" on the butt joints by laminating some unidirectional along each side of those joints when you encapsulate them with glass.
11-22-2012, 11:05 AM #17
11-22-2012, 03:41 PM #18
11-22-2012, 04:48 PM #19
Joe , its all good , and to tell you the truth like Greg mentioned below we just want your re-build to be successful , and stand the test of time !
11-22-2012, 05:03 PM #20
Happy to help Joe. We just want to see your rebuild be successful and safe.
12-04-2012, 06:42 PM #21
Started putting in the first 8' of core over the pad. It was bedded in one evening, then glasses in 24 hours later. After about 12 hours from bedding it in, the adhesion was tested using Ron Pratt's quarter test method. Found a very small void in the area of the drivers seat. A 1/8" hole was drilled to the pad surface and backfilled with resin. Rechecked it before glassing it all in and the different tone was gone. Thanks for the tip Ron!
NY Switzer-Head liked this post
12-04-2012, 07:21 PM #22
5000 RPM
- Sep 2009
- iowa
- 674
Did you vacuum bag it or just wet it out real good?
1975 Hydrostream Ventura II
1987 evinrude 200xp
12-04-2012, 09:42 PM #23
I wetted it out plus used adhesive filler to bed it. Then spread out lots of weight across the top until it cured.
QUOTE=NosBoss;2410218]Did you vacuum bag it or just wet it out real good?[/QUOTE]
12-04-2012, 11:01 PM #24
Looking good. Following it on the other site as well.
Cant wait to see this finished.-Kevin
1982 Hydrostream Vector
1982 Hydrostream Vamp
1973 Hydrostream Vixen
12-04-2012, 11:45 PM #25
5000 RPM
- Sep 2009
- iowa
- 674
12-07-2012, 02:58 PM #26
Got some more core bedded in. Threw a full arsenal of items at it to ensure good adhesion.
LetsBoat liked this post
12-07-2012, 07:05 PM #27
12-08-2012, 02:44 PM #28
Adhesive filler, and what would that be , and to tell you the truth , i really love the nuts and bolts along with the blocks , considering it is something i would do also ...............Ha Ha Ha .[/QUOTE]
01-15-2013, 09:54 PM #29
While cycling through the constants of sanding, glassing and itching, I find myself daydreaming of my finished Viper. I got some more core bedded tonight and got done early. Came in the house and sketched my thoughts on paper. This is what I cameup with........
01-15-2013, 10:04 PM #30
You just need to get that on a T-Shirt now.
Nice Job.
1994 16' Murphy 1991 115 Merc
1985 12' Charger 1989 70 Merc
1981 18'DL Charger 1989 200EFI Merc
