Page 15 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 211 to 225 of 300
Thread: Viper resto-mod
  1. #211
    Nov 2003
    Time to start on the business end of the Viper!
    Attached Thumbnails Attached Thumbnails DSCF4890.jpg   DSCF4893.jpg   DSCF4895.jpg   DSCF4897.jpg
  2. #212
    Nov 2003
    Adjusted the bunks and came up with a great, stable working height.
    Attached Thumbnails Attached Thumbnails DSCF4895.jpg   DSCF4904.jpg   DSCF4906.jpg
  3. #213
    Nov 2003
    There's a lot of work to do before it's straight and crisp. It's a first generation design Viper bottom, do I leave the strakes stock? I have no intention to fill in the pad.
  4. #214
    Sep 2004
    Illinois
    Sharpen and square it all up and light the wicks Joe!! Mine drives itself over 80 with a cleaned up stock bottom.
    1976 Hydrostream Viper - 2.5 EFI
    Resto Thread Here
    2010 Go-Pro Stuff
    "The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
  5. #215
    Feb 2012
    Merritt Island, Fl
    Your photo reminded me of something...
  6. #216
    Feb 2012
    Merritt Island, Fl
    Been following this thread all along. A great job and very inspiring. Sorry the pic isn't straight.
  7. #217
    Nov 2003
    Thanks for the feedback Sonic. Getting closer to lighting that wick! Thanks for staying with the thread V-pad, it's good to be moving forward again.
  8. #218
    Kawarthas
    Hi , I've been following this build too. I'm going to redo mine in a couple of years but have to decide on the original black or the apricot .Very interesting to see how you do it and looks great .
  9. #219
    Nov 2003
    Getting the first grind started. Finding the hull is in pretty good shape, which sure makes the work a lot easier.
  10. #220
    Nov 2003
    Only a few low areas to build up. Once the first grind gets finished, the blueprinting begins.....
  11. #221
    Aug 2012
    beaumont, tx
    Giddy up!!
  12. #222
    Nov 2003
    Got the first coat of epoxy on the bottom. I'll use 2 coats to help flatten and sharpen all the strakes and trailing edges, then it will get painted.
    Attached Thumbnails Attached Thumbnails DSCF4925.jpg   DSCF4927.jpg   DSCF4929.jpg
  13. #223
    What product are you using to epoxy the hull with?
    83 V-King, OPTI. 250 PRO XS on the transom
    Let's Go Brandon, Let's Go Brandon.. Yell it till their heads x-splode.
    Nov 2003
    I first straightened the entire hull with a longboard using 36 grit paper and think this will give the epoxy a good mechanical bite to adhere to. The epoxy that I've been using is West System 105/206
  15. #225
    Nov 2003
    Got the first coat of epoxy sanded down and all the edges straight and crisp
