Page 2 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 16 to 30 of 300
Thread: Viper resto-mod
    Australia
    hi proprider
    Nice work
    I noticed the stringers too. Ginge is correct. Those stringers would be better if they were scarphed. 30 degrees is not enough taper. That is closer to a butt joint than a scarph. You should be looking at a taper of 8:1 for your scarphs. i.e. if the ply is 20 mm thick your taper should be 160 mm long.
    All is not lost though. Put "fibreglass butt straps" on the butt joints by laminating some unidirectional along each side of those joints when you encapsulate them with glass.
  2. #17
    Nov 2003
Name:	DSCF4273 (Copy).JPG
ID:	268412Click image for larger version.
Name:	DSCF4274 (Copy).JPG
ID:	268411Thank you Greg, that's what i'll do. After looking at it again, 30 degree is more like a butt joint. I did put a couple of ribbed bronze boat nails into the scarf and it felt pretty srtong after the epoxy set up.
    Thanks for pointing it out Ginger and everyone have a relaxing holiday.
    Quote Originally Posted by proprider View Post
    The knees of the stringers will not only be glassed to the transom board, they are also locked in both laterally and vertically by a bulkhead. The bulkhead will also serve as a support to glass the splashwell into.
  4. #19
    May 2009
    WEST MICH
    Joe , its all good , and to tell you the truth like Greg mentioned below we just want your re-build to be successful , and stand the test of time !
  5. #20
    Australia
    Happy to help Joe. We just want to see your rebuild be successful and safe.
  6. #21
    Nov 2003
    Started putting in the first 8' of core over the pad. It was bedded in one evening, then glasses in 24 hours later. After about 12 hours from bedding it in, the adhesion was tested using Ron Pratt's quarter test method. Found a very small void in the area of the drivers seat. A 1/8" hole was drilled to the pad surface and backfilled with resin. Rechecked it before glassing it all in and the different tone was gone. Thanks for the tip Ron!
    Attached Thumbnails Attached Thumbnails DSCF4339 (Copy).JPG   DSCF4341 (Copy).JPG
  7. Likes NY Switzer-Head liked this post
  8. #22
    Sep 2009
    iowa
    Did you vacuum bag it or just wet it out real good?
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  9. #23
    Nov 2003
    I wetted it out plus used adhesive filler to bed it. Then spread out lots of weight across the top until it cured.
    QUOTE=NosBoss;2410218]Did you vacuum bag it or just wet it out real good?[/QUOTE]
  10. #24
    Nowthen, Minnesota
    Looking good. Following it on the other site as well.
    Cant wait to see this finished.
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  11. #25
    Sep 2009
    iowa
    [/QUOTE]
    That's good to know. I was under the impression that to install a new core it has to be vacuum bagged. I figured it could be done without, now I know.
    1987 evinrude 200xp
  12. #26
    Nov 2003
    Got some more core bedded in. Threw a full arsenal of items at it to ensure good adhesion.
  13. Likes LetsBoat liked this post
  14. #27
    May 2009
    WEST MICH
    [/QUOTE] Adhesive filler, and what would that be , and to tell you the truth , i really love the nuts and bolts along with the blocks , considering it is something i would do also ...............Ha Ha Ha .
  15. #28
    Nov 2003
    Adhesive filler, and what would that be , and to tell you the truth , i really love the nuts and bolts along with the blocks , considering it is something i would do also ...............Ha Ha Ha .[/QUOTE]
  16. #29
    Nov 2003
    While cycling through the constants of sanding, glassing and itching, I find myself daydreaming of my finished Viper. I got some more core bedded tonight and got done early. Came in the house and sketched my thoughts on paper. This is what I cameup with........
  17. #30
    Ontario, Peterborough
    You just need to get that on a T-Shirt now.
    Nice Job.
    1994 16' Murphy 1991 115 Merc
    1985 12' Charger 1989 70 Merc
    1981 18'DL Charger 1989 200EFI Merc
