Page 11 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 151 to 165 of 300
Thread: Viper resto-mod
  1. #151
    Australia
    Getting near the end now Hard to tell from the pictures ... Did you put a bead of filler down with a gunk bag, and then lay the glass straight onto the wet filler? Eliminates voids, holds the glass into the tight corner, and provides a much stronger joint.
  2. #152
    Nov 2003
    Yes Greg, that's exactly how it was done. Picked up a dispensor thats used for cake decorating and made the paste of epoxy/filler consistancy similar to cake frosting. After it was clamped, the excess was wiped off before it kicked. Lookining from the inside of the hull, there were no visible voids.
    Quote Originally Posted by GregAdams View Post
  3. #153
    Australia
    Nice work.
  4. #154
    Nov 2003
    Now that the deck is reunited with the hull, it was time to get it off the jig. When the jig was built, it was screwed together so that it could be easily disassembled/reassembled. It is available for anyone that may be interested in it for their recore project. It is currently in the Indianapolis area and will soon be in southeastern Michigan. If it doesn't get spoken for, it will become shelving.
    Attached Thumbnails Attached Thumbnails DSCF4133 (Copy).JPG   DSCF4135 (Copy).JPG   DSCF4136 (Copy).JPG   DSCF4138 (Copy).JPG   DSCF4139 (Copy).JPG
  5. #155
    Nov 2003
    Few more detailed pics of the jig
    Attached Thumbnails Attached Thumbnails DSCF4144 (Copy).JPG   DSCF4147 (Copy).JPG   DSCF4151 (Copy).JPG   DSCF4766 (Copy).JPG
  6. #156
    Jun 2009
    central minnesota
    great offer
  7. #157
    Apr 2002
    Wrong Irand, NY
    Nice work!
    Formula 260ss 496HO
    Bender Clan Member
  8. #158
    Nov 2003
    Looks like my Viper will be finishing it's restoration in Southern Michigan. Got it loaded on the trailer and took it for a "rough" ride this afternoon to see how things will travel. It's about a 4 hour trip of mostly highway. When you look at the pics, understand things are just roughed in till I get there. I'm building a new shop and progress will slow down for a bit on the Viper.
    Attached Thumbnails Attached Thumbnails DSCF4778 (Copy).JPG   DSCF4781 (Copy).JPG
  9. #159
    Nov 2003
    After bouncing the rig down some crappy roads, checked the transom to see if there was any signs of stress. Pretty sure with the 1/4" t-6061 aluminum plate on the back, the knees built into the transom along with the added gussets screwed and glassed into the splashwell, transom fatigue and/or sheer won't be an issue.
    Attached Thumbnails Attached Thumbnails DSCF4784 (Copy).JPG   DSCF4785 (Copy).JPG
  10. #160
    Aug 2012
    beaumont, tx
    LOOKING GOOD BROTHER!!
  11. #161
    Sep 2009
    iowa
    I like those gussets you added to the well to help stiffen it up. It should help with the raised transom.
    Where did you get those rigging adaptors you have attaching the hose to the well?
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  12. #162
    Nov 2003
    I got them off of this site. Here ya go:http://www.screamandfly.com/showthre...=tube+adaptors
    Quote Originally Posted by NosBoss View Post
  13. #163
    Jul 2008
    KALAMAZOO MI.
    Anyone know how close a viper hull is to a v king as far as making this jig work? Will be doing a v king this winter and this would be a sweet time saver!!!
    XXXSTREAM
    87 Vegas Xt 200 Merc
  14. #164
    Nov 2003
    The Viper jig has been spoken for and will be going to Michigan for a bicentennial rebuild. Was told it would be available again after that rebuild was completed. Very happy to see that it will be helping keep the hydrostream culture alive.
    Quote Originally Posted by XXXSTREAM View Post
  15. #165
    Sep 2009
    iowa
    Quote Originally Posted by proprider View Post
    I agree. Very cool!
    1987 evinrude 200xp
