Results 151 to 165 of 300
Thread: Viper resto-mod
08-09-2013, 06:30 AM #151
Getting near the end now Hard to tell from the pictures ... Did you put a bead of filler down with a gunk bag, and then lay the glass straight onto the wet filler? Eliminates voids, holds the glass into the tight corner, and provides a much stronger joint.
08-09-2013, 08:11 AM #152
Yes Greg, that's exactly how it was done. Picked up a dispensor thats used for cake decorating and made the paste of epoxy/filler consistancy similar to cake frosting. After it was clamped, the excess was wiped off before it kicked. Lookining from the inside of the hull, there were no visible voids.
08-10-2013, 04:50 AM #153
Nice work.
08-20-2013, 05:03 PM #154
Now that the deck is reunited with the hull, it was time to get it off the jig. When the jig was built, it was screwed together so that it could be easily disassembled/reassembled. It is available for anyone that may be interested in it for their recore project. It is currently in the Indianapolis area and will soon be in southeastern Michigan. If it doesn't get spoken for, it will become shelving.
08-20-2013, 05:05 PM #155
Few more detailed pics of the jig
08-20-2013, 08:10 PM #1565000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
great offer
08-22-2013, 06:26 AM #157
Nice work!
Formula 260ss 496HO
Bender Clan Member
08-25-2013, 03:20 PM #158
Looks like my Viper will be finishing it's restoration in Southern Michigan. Got it loaded on the trailer and took it for a "rough" ride this afternoon to see how things will travel. It's about a 4 hour trip of mostly highway. When you look at the pics, understand things are just roughed in till I get there. I'm building a new shop and progress will slow down for a bit on the Viper.
08-25-2013, 03:22 PM #159
After bouncing the rig down some crappy roads, checked the transom to see if there was any signs of stress. Pretty sure with the 1/4" t-6061 aluminum plate on the back, the knees built into the transom along with the added gussets screwed and glassed into the splashwell, transom fatigue and/or sheer won't be an issue.
08-25-2013, 06:19 PM #160
LOOKING GOOD BROTHER!!
08-25-2013, 07:12 PM #1615000 RPM
- Sep 2009
- iowa
- 674
I like those gussets you added to the well to help stiffen it up. It should help with the raised transom.
Where did you get those rigging adaptors you have attaching the hose to the well?1975 Hydrostream Ventura II
1987 evinrude 200xp
08-25-2013, 07:32 PM #162
I got them off of this site. Here ya go:http://www.screamandfly.com/showthre...=tube+adaptors
08-29-2013, 10:55 PM #163Member
- Jul 2008
- KALAMAZOO MI.
- 39
Anyone know how close a viper hull is to a v king as far as making this jig work? Will be doing a v king this winter and this would be a sweet time saver!!!
XXXSTREAM
87 Vegas Xt 200 Merc
08-30-2013, 04:49 AM #164
08-30-2013, 06:06 AM #1655000 RPM
- Sep 2009
- iowa
- 674
