Results 1 to 8 of 8
    Jul 2008
    Shreveport, LA
    Straight skeg CLE okay to use single engine application?
    Guys is there any reason why a straight skeg lower shouldn't be used in a single engine application? My research tells me that straight skeg lowers were designed for multi engine applications. I recently had a coned 200 case crack on my STV. I have a right hand straight skeg CLE available. Any know problem with using the straight CLE on my STV? Pete
    http://www.screamandfly.com/showthre...interior-re-do
    1986 Skeeter Starfire 150
    2000 Ranger R81VS
    1995 Liberator
    1988 Searay Sorrento
    1986 STV Pro Comp 280 "Area 51"
    1990 STV Pro Comp
    Jul 2002
    FT WORTH, TEXAS
    no if you have hydraulic steering its probably faster then a tabbed swept skegg look at the lowers on the super fast stvs
    Jul 2008
    Shreveport, LA
    Texas20225, thanks for the input. I hadn't looked very closely at other STV setups but I will now. Pete
    2000 Ranger R81VS
    1995 Liberator
    1990 STV Pro Comp
    Lake Coochiching, Ontario
    wouldn't crabbing be a problem with a straight skeg?
    Jul 2008
    Shreveport, LA
    Quote Originally Posted by David View Post
    I do have a tab that I can add.......I am just curious if anyone else has run a straight skeg CLE and their experience in a single engine application. Pete
    2000 Ranger R81VS
    1995 Liberator
    1990 STV Pro Comp
    Sep 2007
    jax fla
    it will have alot of torque on the wheel
    Gothenburg, Sweden
    We have run a straight skeg Sportmaster. It was no good. Lots of torque on the wheel, and you always ended up going in a curve rather than straight. I assume it increased the risk of blow-out, too.
    We changed to a tabbed swept one.
    Jun 2012
    Indiana
    What about if he has hydraulic steering? My 19' Daytona has a straight skeg CLE with hydraulic steering and it does not have any torque steer to it. But at part throttle it does have what i believe you guys call "crabbing" but i just throttle through it.
