Results 1 to 13 of 13
10-17-2012, 08:39 PM #1
Top main bearing feeder hose leak down ?
Should the hose that runs from the bottom of the block to the top main bearing stay full when the motor is off?
I have about 2" of fuel/oil in the hose when I let it sit over night.
When it is idleing, out of gear, it doesn't seem to travel up much at all, but when I put it in gear, it travels up quite nicely to the top....
It also will travel up if I partly cover the bottom carbs with my hand....
Also, when there is a little standing fuel/oil in the bottom of the hose, I can pinch the hose, and the mixture will slightly travel downwards, until I let the hose go, then it will move back up to where it was before....
Is this normal, or should the hose stay full when it sits over night ?JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
10-18-2012, 05:23 AM #2
10-19-2012, 10:20 AM #3
It does travel upwards when I am idling in gear, so I can assume that it is doing its job, ? ...... but its next to impossible to watch when I am under way......
I can rev up a little when I am in neutral, and it "tries" to move upwards....but it seems to move up more when I let off from the rev....
I did take the top of the hose off, and got some fuel/oil to squirt out of the hose.....JOHN MASON
10-19-2012, 10:45 AM #4
10-19-2012, 10:53 AM #5
John: crank case vaccum/pressure changes as the engine revs up and lowers. You'll be fine. I know Halloween is comming up but stop chasing Ghosts.
10-20-2012, 09:48 AM #6
yea....but after losing two top main bearings in a row, (and two cranks), "I see dead motors"
JOHN MASON
10-22-2012, 11:56 AM #7
I believe there is a check valve on top too
1994 202 blazer
K&j modded 2.5
10-22-2012, 01:40 PM #8
Mine has one top and bottom!
10-22-2012, 02:19 PM #9Supporting Vendor
- 11,838
- 163
- 11
- 795
The oil you see in the lower part of the line when motor is off is confirming bottom check is holding..
JayJay @ JSRE
10-24-2012, 11:53 PM #10
Part of my older crank problem may have been that I thought the top was supposed to be a check valve too.....unless I am wrong, the top barb is NOT supposed to be a check valve....but an open barb......(please correct me if I'm wrong)
JOHN MASON
10-25-2012, 06:31 AM #11
Check valve on top
1994 202 blazer
K&j modded 2.5
10-25-2012, 09:40 AM #125000 RPM
- Dec 2007
- Alma, Ar
- 167
- 15
Bottom valve is a check valve so oil will not flow back into engine, top one is just an open fitting so oil can flow to top main bearing. Jim
10-25-2012, 10:10 AM #13
Ok good luck!
dougrussll.com
check out check valves1994 202 blazer
K&j modded 2.5
