Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 115
  1. #91
    Two rights don't make a wrong......what was the cause of the overheat? Nice rig.
  2. Likes wogi liked this post
  3. #92
    Oct 2007
    Impatience and just plain being stupid. Sucking air into water intakes on the non XS lower unit.
    1964 Chris Craft Holiday
    Homemade Glen-l Crackerbox
    71 Switzer 17 with twin Merc 1350s
  4. #93
    What will you be doing to correct the issue? Tie-bar adjusted straight ahead, or toed one way or the other?
  5. #94
    Oct 2007
    They are straight ahead, looks odd from the angle is all. Plugged the top 4 holes and opened up the area between the bottom 3, then fashioned up some scoop type plates similar to the overpriced Mercury ones and bolt thru the 4th hole from the bottom. If I can't hold WP after that I am going to plumb a transom mounted pick-up into the flush port on the side of the gearcase as a last resort. Really just need another XS lower at a price I can afford.
  6. #95
    Quote Originally Posted by boatman14544 View Post
    I remember your post on the trim set up. Pretty slick! The scoops should work. Know a few who did that. Sorry about the power head, but as long as fixable, great! Good luck!
  7. #96
    Oct 2007
  8. #97
    Quote Originally Posted by GENE LANHAM View Post
    -----After you run it the first time---you will probably want to counter-rotate one of the units----
    Torque?;---P-Factor?
  9. #98
    Oct 2007
    any suggestions Gene? The hyd steering helps a ton as far as holding it, however it is a bitch to turn right. Spins left like a champ.
  10. #99
    Nothing simple or easy Michael. A long time ago, we ran an OS boat with three RH units--it did not have power trim--it stretched the limits of Dual Ride Guide.
    I made a LH unit by machining the teeth completely off the FWD gear, I think it worked pretty good (wasn't legal)--soon we got help from Mercury: LH rotation; full gear shift; bronze carrier; pretty good LH props---finding one of those units 50 years later??? Lots of luck--
  11. #100
    South Florida
    11 Post(s)
    Can't you counter-rotate the whole motor? Some guys running Super Speedmasters used to doo that because the left-hand rotation lower had a much shorter life span than the rights. I guess this was because of having all the drive from both pinions going to a single two sided gear on the prop shaft. It would seem to me that keeping forward thrust on the forward gear in the case would be better. All this being said my lower unit experience was with 50s and 850s.
  12. Thanks Mark75H thanked for this post
  13. #101
    South Florida
    11 Post(s)
    Counter-rotating the motor won't work. The forward gear dogs face the wrong way. My bad.
  14. Likes GENE LANHAM liked this post
  15. #102
    WHAT? Steel at that price! But if like me, simple like to build stuff, then unload and "next project"? Screw the money..always can make more, but? NOT A TWIN MERC SWITZER! Miss my 74 SS17, XS, but?..oh well but..(been many boats since, all diff as fun)! Life?..USE IT UP!
  16. #103
    Oct 2007
  17. #104
    Clearwater, Florida
    16 Post(s)
    Very Nice....
  18. #105
    Oct 2007
    Sold the shortys, hanging a couple of Craigslist rats to get back on the water
Name:	phone 15 002.jpg
ID:	413169Click image for larger version.
Name:	phone 15 003.jpg
  19. Likes SCT, Mugs914 liked this post
