Results 1 to 9 of 9
    Sep 2002
    How to ship a prop correctly
    I have covered this topic before... It's time for a fresh thread on the subject.
    A prop must NOT be simply "packed" or "padded" in its packaging, since the blades will be forced to absorb impact, and will typically cut the packing material in transit.
    The method shown below is similar to how Mercury Racing ships their solid-hub props. The two-ply corrugated box is at least 16" square. The entire prop is held and supported by its hub.
    The prop is bolted to a sturdy piece of plywood with large, thick washers and a half-inch bolt. The bolt hole should be located about 1" off-center for 3-blade props, with the blades positioned for even spacing from the edges as shown. Four-blade props should have the hole positioned in the center of the board. It's a good idea to run a belt sander around the bottom edges and corners of the board to keep it from piercing the bottom edges of the box.
    The board is held against the bottom of the box with layers of heavy corrugated cardboard with the grain running vertically. These cardboard pieces are just as important as the plywood board, since they hold the plywood in position. The base board must be held down in this fashion. Extruded sheet foam could also be used as hold-down shims if the box is large enough.
    The box shown is taller than a Mercury Racing box. (This is a cut-down Conga drum box) The top flaps were left double-wide for top strength. I used 3M spray adhesive and heavy packing tape to seal it up. I was able to stand up (150 lbs) on top of this box without damage.
    Perhaps we could keep this pinned at the top to help those who sell a prop here.
    Everybody wins.
    Attached Thumbnails Attached Thumbnails DSC00054.jpg   DSC00055.jpg   DSC00057.jpg   DSC00058.jpg
    Aug 2003
    Sweetwater, New Jersey
    Thumbs up Chad
    I don't always agree with you about politics, but things like this you have chit together. Chuck
    CHUCK & TRACY FREELAND
    1990 25 Talon with twin Merc. 300XS's
    1983 Mako 21 with Merc. 225.
    www.Fullthrottlepowerboats.com
    NEVER FORGET 9/11
    Give a man a fish, and he eats for a day. Give a man a welfare check, a free cellphone, food stamps, section 8 housing, a six-pack of beer and he'll vote for a Democrat the rest of his life.
  3. Thanks vtboy, miuwu208 thanked for this post
    Likes propking874!, miuwu208 liked this post
    Hopedale, IL
    Ditto, nice write up Chad. Thanks mate!
    Nick
    Sunsation 32 Dominator - 496 MAG HOs
    Nothing runs like a Deere when a CAT's on it's ASS!
    Minnesota
    Very nice. Now, if you could just ship that to my house so I can get a better look at it. That would be great. Thanks.
    100 MPH AND NO BRAKES!!!
    2009 Full Throttle STV River Rocket
    1989 STV Pro Comp Ski with a 1994 2.5 260 (Sold)
    Oct 2010
    Greenwood Lake, NY
    Very nice write up. Thanks!
    I was going so slow I almost crashed. - JamesGang
    1978 24 Superboat - 250 EFI
  7. Likes propking874! liked this post
    Sep 2008
    Down The Bayou And In The Sticks, La.
    Dang man why didn't I think of that
    Wilson
  9. Likes propking874! liked this post
    Jun 2009
    Mayfield, NY
    thanks
  11. Likes propking874! liked this post
  12. #8
    Oct 2013
    east tennesse
    Shipping cost suck, bent prop worse, bad vibes by all
  13. #9
    Aug 2012
    Miami,Fl
    Bolt to a piece of plywood and place on other on top and box.
  14. Likes MrG liked this post
