Results 1 to 13 of 13
Thread: 2.5 compression and fuel
10-04-2012, 05:09 PM #1
Would 155# of compression work with 93 pump gas. (With standard timing, box set at 102) 1997 2.5 260 offshore
Thanks, Kurt
1992 Allison XTB 21 / 225 Promax
10-04-2012, 06:04 PM #2
Kurt I sent you an email a while ago... Talk to you later. 102 is plenty fat.
Chris
XS2003 - 280
10-04-2012, 07:28 PM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
As long as the fuel was VERY fresh, the ambient temps were warm, high humidity and the timing was say 23 155 cranking at sea level should be OK, if all those moon and stars didn't line up you could be in trouble..
JayJay @ JSRE
10-04-2012, 07:31 PM #4Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Also depends on prop/load
Erik Kiser
10-04-2012, 08:14 PM #5
Thanks guys, I'm going to double check compression tomorrow with a Snap on gauge. My gauge is a cheap one, numbers are all close, I am just suspect that they are a touch high. This was also a cold engine, shouldn't the #s be a touch higher on a warm engine? Kurt
10-04-2012, 08:39 PM #6Banned
- Dec 2002
- 3,521
Numbers will go down on a warm motor,like 5 lbs...all the oil sittin in cylinders cold gives a higher reading...
10-04-2012, 09:30 PM #793 xr 2001 drag with a 15" drag
92 xb 2002 comp with a 15" drag
R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
10-04-2012, 10:21 PM #8
Living on the edge for sure, and the gaines compared to to the the damage ain 't worth it. JMO. As Jay said if everything is bang on your good to go, but if not. Going to get $$$.
10-04-2012, 10:26 PM #9
doesnt EGTs rise when you retard max advance timing below 25*?
mine are pegging 1250* these days with box at 104% 165psi cranking on 65/35 AV100/91pump
90 degree ambiant air temps"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
10-04-2012, 10:31 PM #10
EGT's can fool a guy, do piston wash and plug checks first and get a baseline. Temp on EGT's are not a good way to base things, after you get plug and piston wash OK you can use the EGT#'s as a warning.
10-05-2012, 12:13 AM #11
10-05-2012, 05:24 AM #12
Will the thicker gasket do or should I look for a set of heads that have not been cut? Kurt
10-07-2012, 03:32 PM #13
False reading on cheap gauge, snap on gauge reads 145. Thanks ! Kurt
