Results 1 to 13 of 13
    Aug 2005
    port orchard , wa
    optimax compressor rebuild?
    Our 250xs compressor is fine now,but its something id like to address before it lets loos.I know theres a newer version available that is supposed to be better.Im just wondering if anyone has had any success rebuilding the stock one.It doesnt look to be that involved.I replaced all the o-rings this summer and took a peek inside.What exactly is the flaw in these and could I a guy do anything to improve it.I have a neighbor that does blueprinting.Is this something anyones tried.
    Aug 2012
    seaford New York
    they are easy to rebuild if you have anything left. most blow up to beyond rebuilding. the most common issue for failure is not cleaning the water screen to the compressor and not changing the oil filters every year resulting in compressor overheats and failures .
    24 Superboat
    New Motors every week
    Jan 2007
    Glen Ellyn, Il.
    Where are the oil filters located ?
    Nov 2005
    Between air intake and under part of the flywheel on the VST's side. You'd have to unplug tps linkage. 2 small white filters (not same filter as the white one going to the motor) make sure you pay attention to the arrows of the new white filters as the new ones I bought had the arrows in different directions to the stock ones...
    Nov 2003
    McHenry,IL
    rebuild is possible but this compressor is made from the casting of a 5 hp force ,my cost 760.00
    needlees to say if not maintained it will fail..........
    www.bottomsupboatrepair.com
    847-
    587-5553
    Complete Service Center
    Nov 2005
    Is this price for the new superceeded compressor?
    Sep 2011
    bay area
    new compressure has two bearings to hold the cranks shaft Vs one for the original. they also added a stud to provide additional
    laterial support.
    The orginal design breaks at top mounting flange
    Jan 2007
    Glen Ellyn, Il.
    At what hours does Mercury state to replace the filters and clean the water screen ?
    Quote Originally Posted by pwrman View Post
    laterial support.
    If you have the old compressor you cannot use the new cap and bearing assembly and have to buy the new compressor. However Mercury now sells all the parts separately for the new compressor.
    Jan 2010
    Vero Beach, FL
    Quote Originally Posted by Scmarineperformance View Post
    Where is the water screen located? I found the oil filters though.
    Thanks for the info, this is great!!
    2001 Velocity 220 - 300
    xs by
    DBR - Sold
    2001 Motion 25, 03-250
    xs's
    Aug 2012
    seaford New York
    Quote Originally Posted by NAVISPEED1 View Post
    on the port side of the mid section you have to take the port pan off and it is an integreated nipple and screen that is to be unscrewed and clean follow the water hose from the compressor to it
    24 Superboat
  12. #12
    Sep 2020
    Mississippi
    What is part number for actual rebuild kit for compressor. Anyone know?
  13. #13
    Sep 2020
    Mississippi
    I found one through walmart believe it or not......
  14. Likes stoker2001 liked this post
