Results 1 to 8 of 8
Thread: 21 Superboat prop?
09-25-2012, 09:45 PM #1New Member
- Jun 2012
- Jacksonville, FL
21 Superboat prop?
Recently bought a 1995 21' SB with a 2008 225 Pro XS, and need some suggestions on a prop. It came with a 4 blade 23p Trophy hitting 59-60 on gps at 5700-5800 WOT in smooth water. It has a jackplate too, running about 2" below the pad, 1/4 tank of gas and 2 people.
I feel this boat should have a little more top end than what I'm seeing right now! Thanks in advance for the help!
09-25-2012, 11:00 PM #2
I'd try lifting it on the jack plate. 2" below the pad seems a little low. i have heard trophy's work well.. once you lift your motor get your speed up... if your on the limiter i'd go with a bigger prop....
21 Skater w/ 250SHO
09-26-2012, 06:09 AM #3
Unless the boat is heavy you should be in the 70's with that engine. You didnt say anything about setback. Hopefully your motors ok cause that is slow for that.
09-26-2012, 07:06 AM #4
I had a shadow with a 200 and no set back it was good for 68 mph was turning a 24 chopper
you should be at conservatively 70 with that set up
09-26-2012, 07:48 AM #5
also when i first got my boat i didn't trim it out enough.. I was doing about 72 MPH when i started getting used to the way its flys and went up on the lift i was up around 80 very quickly. you'll get it going faster.
21 Skater w/ 250SHO
09-26-2012, 09:06 AM #6New Member
- Jun 2012
- Jacksonville, FL
I'll try raising her up in slow increments and see if I pick up any speed. It's setback 6" with a Bob's hyd jackplate.
Frow what I've read, it sounds like the Fury is pretty good, or possibly a chopper. I'm just trying to narrow it down before I start trying a bunch of props.
Thanks for the info so far.
10-03-2012, 09:57 PM #7
For your particular set up and motor I would suggest a 14.5X25"-26" HOSS HPD for best all around use and top end. If you can find one..
Next is Yamaha M25 or Turbo Lightning 24-25.
But testing is the only way to find out what works best for every boat.Last edited by dnelson964; 10-04-2012 at 03:44 AM.
1990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
10-10-2012, 07:39 PM #8
