Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 111
    Feb 2008
    Palm Coast, Florida
    That baby is SOLID! Great job!
    Drive it like you stole it!
    1991 Allison GSE 1998 225 ProMax
  2. #17
    Aug 2012
    BONSALL, CA.
    Quote Originally Posted by hemi2005 View Post
    that baby is solid! Great job!
    thanks, being carefull not to add to much weight, but i figure and extra 25 or so lbs. Means never having to worry. 12" of setback and 500 lbs of motor. Finished glassing in the center pod knee tonite just in time for the debate!!!!
  3. #18
    Aug 2012
    BONSALL, CA.
    Making it tough, like to say the strap was in the plan but looked over my shoulder not knowing how long i had before gell to get it tight. Thanks.....gb
  4. #19
    You are doing a great job on it. Transom looks bulletproof....
    Aug 2012
    BONSALL, CA.
    Quote Originally Posted by xstreamvking View Post
    you are doing a great job on it. Transom looks bulletproof....
    thanks, hey xstream, had a question for you. What material did you use to fill in your splash well? Thought i read your rebuild carefully, but don't recall if you used composite board to span the gap or not. Also, i saved the transon cap, it has an i.d. Of 2", transom is now approx. 2.5". How would you reinstall that cap with the idea of the splash well being eliminated? Thanks again.............john
  6. #21
    I made a panel out of bi ply and divinnycell HPL-80 core. Glassed it inside and out. Glassed that pc to the boat with some bi-ply tabbing. Blended it in with with some torn matt to finish grind. Make the filler/deck panel just short of the transom and lay glass under side first, then lay glass over the top all the way around. V out the seam and glass with bi ply and matt.
    Aug 2012
    BONSALL, CA.
    .........Thanks, do i recall correctly you layed up that panel on a sheet of what (?). after this sheet of hpl-80 and glass has set up, will it have enough flex to match the contour of the forward side of the well? not alot of bend. obviosly transom is flat. would a pic help? when you say bi-ply, you are refering to 1708 right? thanks again!!
  8. #23
    Make a mold that has the correct bend on it. Make any shape changes on it you need, The part will hold the shape after pulling it off the mold. Core will not let it move at all.. I used melamine board over a 2x4 frame. Wax it up and lay up some glass, bed dn core and cover the foam with glass.
    Aug 2012
    BONSALL, CA.
    make a mold that has the correct bend on it. Make any shape changes on it you need, the part will hold the shape after pulling it off the mold. Core will not let it move at all.. I used melamine board over a 2x4 frame. Wax it up and lay up some glass, bed dn core and cover the foam with glass.
    ok, what thickness dininnycell hpl-80, thanks
  10. #25
    1/2'' - 3/4'' any size will do. Any type of core will do. It could be scrimmed and scored too, if it needed to bend very much.
    Aug 2012
    BONSALL, CA.
    [QUOTE=XstreamVking;2388197]1/2'' - 3/4'' any size will do. Any type of core will do. It could be scrimmed and scored too, if it needed to bend very much.[/QUO THANK YOU...........GONNA TRY AND MAKE IT RUN LIKE THIS ONE I HAD IN 1985.Click image for larger version.
  12. #27
    Feb 2008
    Palm Coast, Florida
    Don't forget to take more pics as you go.
  13. #28
    May 2009
    WEST MICH
    Aug 2012
    BONSALL, CA.
    Update, finished up glassing in the knees and building battery mount pads. Had to support the sides of the hull with a strap as hull had relaxed about 1/2". Got the deck lined up with temp wood supports and deck screws to hold it all together. Added 2 layers of 1708, in staggered widths and lengths at underside of deck at transon. Also same along hull joint " its a butt joint" so no margin for error. Ground out a v at the cut line 4" wide almost to the 1708 on the underside. Again wetted out random length and width 1708 and filled in the v out area a little above grade of original gel. Will grind smooth tonite. So far so good, looking forward to moving on to bulkheads and sponson/deck supports. Thank you all!!!
ID:	266040Click image for larger version.
ID:	266041Click image for larger version.
  15. #30
    May 2009
    WEST MICH
    Dam ............l@@king g@@d and not to mention that you are moving right along . Nice work .
