Results 1 to 11 of 11
Thread: Trailer Tires
09-17-2012, 10:00 AM #1
Trailer Tires
Hello,what is a good trailer tire to run,or what is everybody using. Goodyear Marathon's ??
Thanks
11-16-2012, 09:39 AM #25000 RPM
- May 2003
- Fond du Lac WI
- 813
- 18
- 84
- 72
- 405
I've run Carlisle only because they came on the trailer, had Duro on my 5th wheel camper that are absolutely junk, came apart after less than 5000 miles, tread separated from casing. Right now I am running Goodyear Marathons, only have 3500 miles on them on the 5th wheel, but so far so good.
11-16-2012, 01:18 PM #3Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Put a set of power king towmax tires on my tandem trailer. Run them at 70+ mph for 1-2 hrs at a time and no problems.Priced good. Made in the U.S.A. Used to run the denman tires made in mexico, until they dry rotted. They were good tires, but wanted some made in the US tires. Chinese tires are the worst, stay away, or get used to changing tires on the side of the road.
11-16-2012, 06:27 PM #4Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Trailer tires are notoriously junk, and very few last worth a flip before crapping out early... Use light truck/car tires, just make your the tire is rated for the weight it'll be carrying by a comfortable margin(I'm captain obvious, I know)...
Kevin Kiser
11-16-2012, 10:33 PM #58000 RPM
- Sep 2006
- not here
- 3,376
- 204
- 423
- 386
- 693
My Marathons are 10 years old now and no plans to replace them. Many of my friends who dislike the Marathon, went to Kuhmo. They have a load range D tire available. I have the original Armstrongs (NLA) on my 1986 pop-up camper, still looking good.
'03 21ft Inboard skiboat V-8
'70 14ft Winner, 90hp Merc
'22 21ft Inboard skiboat electric
11-16-2012, 11:13 PM #6
Hey electricjohn--
Be aware--at 10 years old, tires are considered unsafe due to aging of the rubber regardless of miles. You are really looking for trouble on your 1986 tires, and were it me I would repalce the 10 year old Marathons.
Though I got to admit--hard to tell you to replace 10 year old tires when you are still scucessfully running 26 year old tires.Last edited by Li'l Toy; 11-16-2012 at 11:14 PM. Reason: go to admit...
Per Rock:
"Once I bought my first Hydrostream boating changed forever for me."
Per my hero Instigator:
"I try not to let common sense interfere w/my boat buying decisions."
Pat Gent
cell 954-249-3246
'78 Hydrostream Vandal (being rebuilt)
'86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
11-17-2012, 05:21 PM #7Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
If you keep the speed down to 60 or so, tires will not blow out nearly as often. It's the speed that heats them up and kills them. I too am capt obvious....
11-18-2012, 09:33 AM #8
11-18-2012, 07:40 PM #9TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
11-18-2012, 07:43 PM #10
Frank where you do alot of towin stuff .whats a good tires for trailers..................
11-18-2012, 07:59 PM #11
my stream trailer had marathons,liked them,i see all kinds of trailer tires,and for the most part if there under 5 years old they will be ok,after that it gets bad at long high speed tows,if ouly local you should be ok at 5 years and older....for a while longer..................bearings thats another story...................
