Results 1 to 8 of 8
    Sep 2012
    Fort Lauderdale
    2007 175 Etec . Why with only 300 hrs of use would the rod just snap ?
    Any Idea why with only 300hrs of use would the #3 Rod snap ?
    Aug 2012
    seaford New York
    was the piston seizing from a lean condition? this is the most common problem with an etec in 07
    24 Superboat
    New Motors every week
    Sep 2012
    Fort Lauderdale
    Quote Originally Posted by Scmarineperformance View Post
    Yes the cylinder is scored and there is a little metal transfer . I was so upset that the rod busted up the whole block that i didnt even noticed . Any idea why the cylinder received less oil ?
    May 2001
    Hickory NC
    Possibly dirt in the oil system. Were the filters changed at the 3 yr/300hr service? What oil were you running? What does the piston top look like? What was your max rpm? Any codes?
    subscribed
    Oct 2010
    Harrisburg,Pa
    Water in the oil system,I have found water in the oil tank of many blown motors. This is a problem when people don't take care of there oil system,condinsation is a big problem,you must keep the oil tank full at all times.
    I found this much water in the oil tank of a merc I just tore down for a customer. They cant live on that.
    May 2001
    Hickory NC
    Greg is correct we find water in alot of tanks when we service them. Have a Merc in right now with a rod out the side and the tank had more water than oil.
    Jul 2007
    Ms. gulf Coast
    thats prob what they ill find, condensation is a big problem, in both fuel and oil tanks.
